RPM Surge - BMW Forum - BimmerWerkz.com
Old 08-04-2011, 09:25 PM   #1 (permalink)
Car: 2000/BMW/323i
Farrpost is on a distinguished road
RPM Surge
I have a 2000 323i. When I take my foot off of the gas the RPM's surge by 500 to 800 and the car lurches forward like it is bogging down.
It has also stalled when I am starting up from a light.
No codes are present.
Any thoughts on this?
Farrpost is offline   Reply With Quote
Old 08-06-2011, 09:17 AM   #2 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
ICV or cam sensor!... Maybe remove and clean the Throttle body!
Easy fix...
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 08-06-2011, 11:13 AM   #3 (permalink)
Car: 2000/BMW/323i
Thanks for answering.
I changed the intake side cam sensor.
I also cleaned the ICV but the problem persists.
Could it be transmission related?
Old 08-07-2011, 07:59 AM   #4 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Is it an auto box? If yes then it could be a cable issue...
Your motor is the reduced powered M52 unit, generally the gearbox should only raise the revs when D or R is selected but 800rpm is fine
Eso es todo!
BMW Part Market
New Member ?
Old 08-07-2011, 04:02 PM   #5 (permalink)
Car: 2000/BMW/323i
Yes it is an automatic trans. It also has the M/S.
When the car begins to lurch forward and the RPM's jump as I'm decelerating if I put it into neutral the problem stops right away.
I am totally confused.
Old 08-25-2011, 03:30 PM   #6 (permalink)
Car: 2000/BMW/323i
Please Help!!!!
I have changed the boot between the MAF and the throttle body.
I have cleaned the MAF.
I have cleaned the ICV.
I have removed and cleaned the Throttle Body.
I have changed the Intake Cam Position Sensor.
I have changed the CCV and all 4 hoses associated with it.
The car has not thrown a code in 2+ weeks and 1500 miles.
Yet the car still bucks and the RPM's jump up 5-700 when I take my foot off the gas as I decelerate on an exit ramp.
Rev Surge at Start twoTONEs 3-Series (E36) 2 11-16-2010 10:27 PM
Surge Performance Chip for M3? cacampers M-Series (M1, M3, M5, M6) 9 11-18-2009 01:46 PM
odd idle surge... Lethal325is 3-Series (E36) 0 03-06-2006 10:25 PM
idle rpm surge.... again SD318is 3-Series (E36) 2 11-03-2005 09:27 PM
Occasional Stall Or Surge Essex502 5-Series (E12,E28, E34, E39, E60) 4 04-07-2005 08:41 AM
