Reverse parking sensor probs - BMW Forum - BimmerWerkz.com
Old 05-09-2008, 02:44 PM   #1 (permalink)
E Hanna is on a distinguished road
Angry Reverse parking sensor probs
Hi, until recently all was well with the reverse parking sensors on my 53 plate E46. Now all I get is a continuous beep for about 5 seconds and then nothing, not even a warning if I'm right up to an object. Advice would be much appriciated!!
E Hanna is offline   Reply With Quote
Old 06-13-2008, 12:21 AM   #2 (permalink)
pulvil29's Avatar
Car: E36 328i convertible + 530d tourer
pulvil29 is on a distinguished road
one of your sensor has been damaged. pehaps just a scratch from a bush can do it! unplug each sensor in turn untill problem stops then replace the one sensor. hope this helps..
pulvil29 is offline   Reply With Quote
Old 10-26-2008, 04:04 PM   #3 (permalink)
owenmoney is on a distinguished road
How are the parking sensors removed? Are they pulled out or pushed in?
owenmoney is offline   Reply With Quote
Old 04-18-2009, 12:47 PM   #4 (permalink)
multiplexor is on a distinguished road
Hi,
did you manage to solve the problem with your parking sensors? I have also got the same problem.
Thanks
Mike
multiplexor is offline   Reply With Quote
Old 04-20-2009, 02:44 PM   #5 (permalink)
Hi Mike, my parking sensors are on the rear bumper and I used a drift to knock them in toward the car, once the damaged one was loose it's easy to take the wiring off, put the wiring on the new one and re-attach, it's just possible to get a hand inside the bumper, but make sure your model is OK for this.
Old 04-20-2009, 02:59 PM   #6 (permalink)
Hi, did you manage to get your parking sensors working?
Was it a faulty sensor?
I am getting the same problem (continuous beep for about 5 seconds then they do not work).
Thanks
Mike
Old 06-06-2009, 12:39 PM   #7 (permalink)
haddin23451 is on a distinguished road
Parking Sensors gives safety to your vehicles and keeps your vehicle in excellent condition. This has been mainly designed for SUV's, trucks, vans. The poor rear visibility of many cars, SUVs and other large vehicles increases the risk of hitting obstacles like small object, or even people when driving in reverse. With backup sensors installed, drivers can lower the risk of collision when backing up or parallel parking. So Using could bring safety to your car.
__________
haddin
Are you from Area 51? Parking things, what science!
haddin23451 is offline   Reply With Quote
Old 06-09-2009, 09:22 PM   #8 (permalink)
MichaelRoger is on a distinguished road
Cars with reverse sensors results in lazy drivers that relies on the sensor to warn them of any object behind the car.. thus when they reverse w/o really checking, the ramp their cars right into railings or objects... rather not have sensors.
Again with parking help, here they are called valets - who knew!
MichaelRoger is offline   Reply With Quote
Grinding Noise When Parking In Reverse teresa 3-Series (E46, E90) 2 05-29-2005 10:05 AM
Hesitiation.mass Airflow Sensor Or Cam Pos Sensor? scopefrfd 5-Series (E12,E28, E34, E39, E60) 7 04-24-2005 11:47 AM
E36 M50 Coupe 1993 Rear Parking Sensor/s gphillips 3-Series (E36) 2 04-21-2005 06:40 AM
Reverse Light Sensor Problems... daxsandman 3-Series (E21, E30) 2 10-22-2004 07:28 PM
Cluch Probs USCS_POO 3-Series (E21, E30) 3 09-06-2004 06:19 PM
