Replacing window motors - BMW Forum - BimmerWerkz.com
post #1 of 12 (permalink) Old 03-02-2004, 11:42 AM Thread Starter
otamara67 is an unknown quantity at this point
Can someone tell me if they have replaced a window motor and is doing it yourself a possibility? Can you also tell me how to be sure it is the motor because I can still hear the motor if I press the button. I think that it is a possibility someone slammed the door hard and could have caused the window to come off the track because the window fell down and I had to wedge something between the window and the frame to keep it up. If I can do it myself where can I get the motor and directions on how to do it. Any resonse is greatly appreciated. ghead
otamara67 is offline
post #2 of 12 (permalink) Old 03-02-2004, 03:13 PM
CBA
CBA's Avatar
CBA is an unknown quantity at this point
Send a message via MSN to CBA Send a message via Yahoo to CBA
pop the door panel open first dude.. youll need a philips screw driver and a flat head with a rag attached to the flat part so not to hurt your door trim. take out all the screws and gently pry out the door panel from the door.
and if you want more exposure to this thread to get the help you need post in the rooms at the forums main page that correspond with the type of car you have..please be more specific. those rooms are designated for your car and only the owners of those cars and the 2 tech mods post in them, so you will get a good idea of whats up.
its listed
3-Series (E21, E30)
3-Series (E36)
3-Series (E46)
5-Series (E28, E34, E39, E60)
M-Series (M3 & M5)
6,7,8,X,Z - Series and Mini Cooper
pick one.
all you ever need for the toronto night life <a href='
target='_blank'>click here</a>
<img src='
you know your not paying attention when this happens:
<div class='quotetop'>QUOTE</div><div class='quotemain'>Are you refering to his Signature? oh shit, i just remembered i used my name in my sig... I just 0wn3ed myself. </div>
-Founder
CBA is offline
post #3 of 12 (permalink) Old 03-02-2004, 03:18 PM
ex owner/admin
Furious's Avatar
Quoted: 1 Post(s)
what type of car do you drive hommie
Furious is offline
post #4 of 12 (permalink) Old 03-02-2004, 03:31 PM Thread Starter
Thanks for responding I did post also under e46 and btw I'm a dudette,chick, female, lady. I have a 323I for the one that asked year 2000 sedan. :P
post #5 of 12 (permalink) Old 03-02-2004, 03:33 PM Thread Starter
BTW I did pop open the door panel, that's how I got the window back up and wedged something in it to keep it up. But I don't know what to look for.
post #6 of 12 (permalink) Old 03-02-2004, 05:05 PM
Mach 5's Avatar
Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute
I know that the motor is rivited to the door so you would have to drill the rivits out. There are bolts that attach the window to the track. I would first look to see if the bolts are all in place prior to doing anything as you will mot likely have to take the glass out of the door to replace the motor. If the motor runs it is most likely the track you may have to buy the entire assembly though. I believe this in not an uncommon problem so someone who has had this happen please chime in.
Ben
&quot;It's not because I'm an aggressive driver, it's because I'm an idiot&quot; actual quote from my wife.
Mach 5 is offline
post #7 of 12 (permalink) Old 03-02-2004, 05:42 PM
CBA
CBA's Avatar
sorry lady
<img src='
-Founder
CBA is offline
post #8 of 12 (permalink) Old 03-02-2004, 06:05 PM
EXtech's Avatar
the motor is NOT riveted to the door. The E46 window regulators are bmw's easiest ones to replace. And YES, the regulator needs replacing and not the motor. Typically the cables break inside those things or the plastic guide breaks and the cable comes loose. If you want a step by step instruction on how to do it then email or pm me and I will go through it... don't have the time right this second. The only pain in the but thing are having the right tools and getting the 8mm screws out of the window clamps. E46 regulators go out allllllll the time. I have done millions of them and would suggest getting used to replacing them.
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
STETT Performance Official Grand Opening BMW Meet, May 6th 11A-3P -- Music, Food, Drawings and Tons of BMW's go to
and register.. it's FREE
EXtech is offline
post #9 of 12 (permalink) Old 03-02-2004, 06:07 PM
CBA
CBA's Avatar
lol kinda like the door handles on the 5ers..
<img src='
-Founder
CBA is offline
post #10 of 12 (permalink) Old 03-02-2004, 06:12 PM
Mach 5's Avatar
So they are not Rivited, I must have been thinking about VW regulaters, same thing happens though.
Ben
Mach 5 is offline
post #11 of 12 (permalink) Old 03-02-2004, 09:49 PM Thread Starter
Thanks for responding, can't do it til this weekend now.......
post #12 of 12 (permalink) Old 03-03-2004, 01:54 PM
EXtech's Avatar
Mach, you're thinking of the E36 regulators and motors... real pain in the A**
STETT Performance -
Everything BMW
Plano, TX 75074
469-767-3309
EXtech is offline
Replacing Ride Side Door Window Glass!!! mycro_machine 3-Series (E46, E90) 3 08-04-2016 04:11 PM
Window Trouble Sporty540 5-Series (E12,E28, E34, E39, E60) 4 01-10-2005 11:49 PM
Diy Replacing Convertible's Rear Window? rajivmehra 3-Series (E36) 2 12-20-2004 03:19 PM
Passenger Window Exterior Trim epistemology 3-Series (E36) 5 09-27-2004 03:28 PM
Power window fun! kestrel325is 3-Series (E36) 7 07-17-2004 09:56 PM
