Replacing Headlamp Assembly - BMW Forum - BimmerWerkz.com
Old 11-03-2004, 11:03 AM   #1 (permalink)
NascarSigEp is an unknown quantity at this point
I am planning on replacing my headlamps with aftermarket Bi-xenons and I "tried" to remove the stock assembly and just ended up leaking a bunch of washer fluid on the ground. Has anyone done this, just removing the stock assembly with the headlamp squirters? Any information would be great. Thank you.
NascarSigEp is offline   Reply With Quote
Old 11-04-2004, 10:56 PM   #2 (permalink)
jlevi's Avatar
jlevi is on a distinguished road
Send a message via AIM to jlevi
[snapback]223646[/snapback]
If you pull off the caps on the front it's a lot easier.
I hope you're putting in Projector46's from www.jlevisw.com
JL
jlevi is offline   Reply With Quote
Old 11-05-2004, 11:36 AM   #3 (permalink)
Caps? I was going to get the ones on www.umnitza.com. They look like the same ones and cheaper. Are the otherones better? I haven't purchased these yet so any help would be greatly appreciated. Oh, what is the difference between a touring and a saloon? What's a saloon?
Old 11-06-2004, 10:34 AM   #4 (permalink)
M BMW is an unknown quantity at this point
Hi!! How are you? I can't help you with the headlights but I can tell you the difference between a saloon and a touring.
Saloon's are basically sedans (I think). Touring are station wagons.
Thanks.
BYE.
M BMW is offline   Reply With Quote
Old 11-06-2004, 11:46 AM   #5 (permalink)
Awesome. Thank you!
Headlamp washers not coming out Morpheous 3-Series (E46, E90) 5 11-13-2005 04:13 PM
Replacing Mast Antenna offabroadway 3-Series (E21, E30) 11 05-24-2005 05:48 PM
Broken Fog Light Assembly pamato 5-Series (E12,E28, E34, E39, E60) 0 04-12-2005 10:56 AM
Drl Headlamp Relay Problem (daytime Running Light) tonyhon 3-Series (E36) 5 01-18-2005 07:42 PM
95 E34 Headlamp Assembly Removal newdad52001 5-Series (E12,E28, E34, E39, E60) 3 12-04-2004 08:02 PM
