remvoe the damn lens - BMW Forum - BimmerWerkz.com
Old 07-06-2004, 09:07 PM   #1 (permalink)
tgeppes is an unknown quantity at this point
hey guys i am kinda new here but i have having major problems
my left front turn signal has gone out and i am having a hell of a time
replacing the blub cause i do not know how to get into the lens... how do you
do it... i can take off all the panels and stuff for the headlights but then i cant
anything about the turnsignal
please help
~teppes
tgeppes is offline   Reply With Quote
Old 07-06-2004, 10:04 PM   #2 (permalink)
Moderator
Dirty_Tool's Avatar
did you mean to say e46?
DT
Old 07-07-2004, 06:20 AM   #3 (permalink)
yea sorry
any help?
Old 07-07-2004, 12:58 PM   #4 (permalink)
Mach 5's Avatar
Mach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond repute
There is a hole in the fender above the turn signal put a flat headed screwdriver in there and release the tab that holds the turn indicator to the headlight assembley. (It moves to the right and left, Not up or down, and should not require force to move) The indicator should then slide out. On some models there is a nylon screw accessable through this same hole that needs to be loosened to remove the indicator. If you shine a flashlight down the hole you should see either the tab or the screw I am talking about.
Ben
"It's not because I'm an aggressive driver, it's because I'm an idiot" actual quote from my wife.
Mach 5 is offline   Reply With Quote
Old 07-21-2004, 03:09 PM   #5 (permalink)
GDBJLB is an unknown quantity at this point
I had exactly the same problem, and was very frustrated. Finally found the answer by looking at a picture of some after market clear lens replacements - (found elsewhere on this forum). There I noticed that there are two tabs that extend from the front lens towards the rear. The top one (the one you can see if you look down the hole in the wing) is orientated vertically and only acts as a guide. DO NOT BEND THIS ONE! There is a second tab that is orientated horizontally and is about 4-5" below the access hole in the wing. This tab has a dog tooth design. Push gently down on this tab, and the lens will slide out easily. I empathise with your frustration. I spent hours bending the heck out of everything I could see only to realise I was bending the wrong tab. Once I figured it out, lens replacement can be done in seconds!
ghead
GDBJLB is offline   Reply With Quote
Removing The Oem Bumper Lens??? M3|02 M-Series (M1, M3, M5, M6) 0 04-08-2005 09:18 AM
Brakelight Lens Conversion motorwaybmw 3-Series (E21, E30) 5 12-30-2004 02:27 PM
Replacement Fog Lens Paraklas 3-Series (E21, E30) 1 11-16-2004 11:24 AM
Early Model e30 iS AIR DAMN not es 86325LSD Classifieds Sell & Buy 3 07-08-2004 01:22 AM
New lens (biggie pics=56k nono) woobiee Picture Showroom 31 06-09-2004 11:27 AM
