Remote key battery replacement! - BMW Forum - BimmerWerkz.com
Old 04-10-2010, 10:44 PM   #1 (permalink)
Bombay Badboy is on a distinguished road
Question Remote key battery replacement!
I recently purchased a 2001 325i(or Xi) and the remote key worked 2wice maybe but was very delayed, now it doesnt respond whatsoever. I have also tried to resync the key without success.
I read here:Diamond Key Battery Replacement - E46Fanatics
He stated replacing the battery TYPE (Panasonic VL-2020 Lithium Coin Cell battery) from any shop that sells specific batteries will fix the problem.
The problem is that i only have ONE key with this car, one master.
Can i still perform the procedure above mentioned in link with success??
thank you!
Bombay Badboy is offline   Reply With Quote
Old 04-11-2010, 12:53 PM   #2 (permalink)
Festivus yes, bagels no..
yammahamma's Avatar
Car: '01 330i
yammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to behold
Send a message via Yahoo to yammahamma
The battery should charge itself if you drive for a long distance. But that will only work if the battery can hold a charge.
yammahamma is offline   Reply With Quote
Old 04-11-2010, 01:27 PM   #3 (permalink)
So chances are likely, being almost 10 years old, and probably used as the master key for 90% of the time, it may be safe to say that the battery can no longer hold it's charge?
Old 04-11-2010, 03:14 PM   #4 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
^^ That is VERY likely the case.
Turkey Fleet Bond Holder
Old 04-11-2010, 10:19 PM   #5 (permalink)
.. And so by replacing such battery, remote key may work again, after resync??
Old 04-12-2010, 01:11 AM   #6 (permalink)
yammahamma's Avatar
Car: '01 330i
if you break it, you could just use it manually open the car by sticking in in the hole. ()
Old 04-12-2010, 08:59 PM   #7 (permalink)
Thats my current method, But i was concerned if i accidentally destroyed the circuitry if it will still lock/unlock manually..?
Need Help With Key Remote jose11369 5-Series (E12,E28, E34, E39, E60) 1 06-28-2009 08:00 PM
No Remote - Just Key ? Chumley 3-Series (E46, E90) 0 03-09-2009 11:29 AM
Buying a replacement remote key comncense 3-Series (E46, E90) 1 12-28-2005 11:56 PM
Key remote interboss 3-Series (E46, E90) 9 09-15-2005 05:49 PM
new replacement remote key bolle330i 3-Series (E46, E90) 6 12-10-2003 01:35 PM
