Recommended Tire Size - BMW Forum - BimmerWerkz.com
Old 04-02-2005, 11:42 AM   #1 (permalink)
Courtney is an unknown quantity at this point
Send a message via AIM to Courtney
I just bought a 99 323i that's been lower with Eibach ProKit. I also got a set of 17x8.5" (front) and 17x9.5" (rear) Breytons with the car. The wheels have 235/40-17 on the fronts, and 245/40-17s in the rear.
I'm going to replace all four tires, and put the wheels on the car. The front tires look okay size wise, but the rears look a little small (not wide enough).
What's the recommended tire size for both wheel sizes, and will they fit my lowered car without rubbing?
Thanks...
Courtney
<img src='http://v8eaters.com/uploaded/cgw/supsig6.jpg' border='0' alt='user posted image' />
430.96 RWHP
Daily::99 BMW 323i
Courtney is offline   Reply With Quote
Old 04-02-2005, 01:02 PM   #2 (permalink)
The 17x9.5 rear with a 245 on it.
Courtney
430.96 RWHP
Daily::99 BMW 323i
Old 04-02-2005, 01:19 PM   #3 (permalink)
WOT in Reverse
jllphan's Avatar
A 9.5" wheel gives you plenty of room to slap some wide shoes on. You could go up to a 275, but that's probably a bit overkill. A good set up would be 235/45ZR17's up front and 255/40ZR17's outback, this would yield a difference of less than 10 revolutions per mile (front to back), and is very good for a staggered set up.
Old 04-02-2005, 02:00 PM   #4 (permalink)
woobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond repute
Send a message via AIM to woobiee
with 9.5 you can def put a wide tire but for a 3 series non M and especially when its lowered, im pretty confident you will be able to put 255 wide tires max in the rear. unless you wanna go roll your fenders
woobiee - Anamorphic Cycle
woobiee is offline   Reply With Quote
Old 04-02-2005, 07:28 PM   #5 (permalink)
Thanks for the info, guys.
I'm thinking about a 255/35 in the back, and whatever matches that best up front. I would like for the tires to have a little less of a profile as well. Also, going with a 35 over a 40 in the back will help prevent rubbing, correct?
I'd like to avoid rolling my fenders.
Courtney
430.96 RWHP
Daily::99 BMW 323i
Old 04-03-2005, 03:04 AM   #6 (permalink)
Str8crusin is an unknown quantity at this point
Will 225/40/18, 235/40/18, or a 245/40/18 fit like stock (without pulling the fenders) on a 2000 323ci???
Thanks
Str8crusin is offline   Reply With Quote
Old 04-03-2005, 10:39 AM   #7 (permalink)
gaurantee 235/40 or 225/40 will fit without rubbing issue on 18
Old 04-04-2005, 11:17 AM   #8 (permalink)
[snapback]324383[/snapback]
How is the ride? Is it really that much noticable from 16's or 17's???
I just want to make sure if I put some 18's on that my 323ci will drive just as nice.
Old 04-04-2005, 01:07 PM   #9 (permalink)
ive been on coilovers for a while now and i dont think i remember how it was without the that setup.
i think the ride was abit stiffer. and depending on tire, my tires were 'louder' than my stocks. even using the same brand/type tires, 16 vs 18, the 18 will exert more road noise.
Tire Size For 323i BigStone 3-Series (E46, E90) 3 05-24-2005 10:18 AM
What Tire Size For My 18x8.5 Rom?? BigAls330ci 3-Series (E46, E90) 2 04-26-2005 02:26 PM
Best Tire Size unjustjust 5-Series (E12,E28, E34, E39, E60) 4 01-18-2005 09:59 AM
