Real Differential Whine - BMW Forum - BimmerWerkz.com
Old 04-06-2004, 11:04 AM   #1 (permalink)
tico is an unknown quantity at this point
I've got a 2000 323Ci manual. At certain speeds, in certain gears, at a certain load, the car makes a loud whine (loud enough that you can't drown it out with the radio). The whine is most problematic at highway cruising speeds (in 5th gear, travelling 90+ mph.
It took a few years, but the dealership finally narrowed it down to the rear differential. Apparently, BMW has issued a TSB on this for 2000 and 2001 3 series. Despite many attempts, the dealerships have given up and declared the problem unresolvable.
Has anyone else encountered this, or found a way to fix the problem?
tico is offline   Reply With Quote
Old 04-06-2004, 03:13 PM   #2 (permalink)
WestEast is an unknown quantity at this point
I posted something similar (see "High Pitched Sound", 24Mar2004). I only hear it if I lightly touch the accelerator, at steady speed anywhere between 50 - 100 KPH. It starts mid-pitch, and rises slightly in pitch as the speed gets higher. It sounds like it is coming from the rear. When I lift off the lightly touched accelerator, it disappears. I would have guessed something like a fuel pump... anyway, car has appointment with BMW engineers tomorrow to investigate.
Dave used
WestEast is offline   Reply With Quote
Old 04-07-2004, 10:29 AM   #3 (permalink)
What make/year/transmission do you have? Please post the diagnosis of your serviceman. Thanks
Old 04-07-2004, 03:37 PM   #4 (permalink)
Mine is a 2003 320iA. I just came back from AutoWest BMW, Richmond, BC. The 'chief engineer' accompanied me on a test drive. He heard it, and took lots of notes. Didn't think it was the fuel pump - because that runs at a single speed. He did mention "differential". Ugggh. They want the car in for a few days - as he said, could be hours, could be several days. It goes back to them next week, and I'll be given a loaner. Glad it is under warranty!!
Dave
Old 04-07-2004, 07:33 PM   #5 (permalink)
this happens often when the diff is filled with improper lubricant (gl-4 vs gl-5). i do not know the answer here, but if they give you a new diff, make sure what the spec lube should be....
peter
Old 04-13-2004, 06:02 PM   #6 (permalink)
My car was in with the dealer today. Just got a report from them, they did some adjustments, changed the diff oil - but still had the whine. They have decided to change the whole diff. The order has been placed, apparently has to come from Germany and will take 2 weeks to arrive. Will this be the cure ? I'll report back.
Old 04-13-2004, 06:05 PM   #7 (permalink)
e36_m3_Turbo's Avatar
this is a very known problem in the diff. in the e46. i thikn our memeber az325ci had a problem too.
No longer red.
Old 04-28-2004, 03:12 PM   #8 (permalink)
lenk is an unknown quantity at this point
I have just bought a 2003 320iA demo with 29K on the clock and have found the same whine problem. Very pronounced whine at 100 -120 km per hour. Dealer rebalanced tires and rotated tires with no affect. Same as you guys, whine goes if you take foot off throttle. Suggests to me a transmission problem probably the diff. Taking car back to dealer.
LenK
lenk is offline   Reply With Quote
Old 05-01-2004, 06:24 PM   #9 (permalink)
Following on from my previous correspondence, the car went in for a new diff. THE WHINE HAS GONE. How nice to cruise in silence!! Work was done under warranty. Hey Lenk - are you in Canada ? Mine is a 2003 320iA with 23K km. The dealer who fixed this was AutoWest BMW in Richmond, BC. The chief engineer is a guy named Andy. They ended up calling BMW Canada to get approval for the new diff.
Old 05-01-2004, 06:41 PM   #10 (permalink)
its common in e46 like i said. just demand a read differential replacement.
No longer red.
Old 05-07-2004, 07:58 AM   #11 (permalink)
Hey WestEast great news to hear your diff whine has gone. Yes I am in Canada in Oakville, Ontario. Took my BMW back to the dealer and they are following a process of eliminating the problem. First they tried the tires to no avail. Now they have ordered a new drive shaft under warranty to see if that is the problem. I know it is the diff and wish they would get on with it and replace it under warranty. The whine is really getting on my nerves now. Wish me luck
What engine ,tranny and differential fluid i should use in my 89 325i Slow325i 3-Series (E21, E30) 2 11-03-2005 02:42 AM
Alternator Whine Only When Lights Are On YoungExec728 Audio and Electronics 5 10-01-2004 12:17 PM
Differential Groaning noise (FIXED!) shield 3-Series (E21, E30) 0 09-12-2004 04:56 AM
differential viali8 3-Series (E21, E30) 0 04-24-2004 05:56 PM
Differential Service Bulletin roloson M-Series (M1, M3, M5, M6) 0 01-06-2004 06:02 PM
