Rattling Noise - BMW Forum - BimmerWerkz.com
Old 03-31-2005, 02:35 PM   #1 (permalink)
white 330ci is an unknown quantity at this point
i noticed a rattling noise coming from the back of my car, it happened at low speeds over bumps. it sounded like a metal on metal vibration, after poking around underneath my car i eneded up being the metal shields right behind my rear rotors. they were just bent out of shape.
if you have the same problem, then you should check this, jack up you rear end and smack your tires from underneath, with some force. if it rattles then you just need to bend the sheilds untill it doesnt rattle anymore.
i know someone else had this problem...
white 330ci is offline   Reply With Quote
Old 03-31-2005, 08:10 PM   #2 (permalink)
Aloyouis is an unknown quantity at this point
[snapback]322314[/snapback]
Thank you for thinking of all of us when you fixed your own issue. More of us will do the same.
JIM
Aloyouis is offline   Reply With Quote
Rattling noise when A.C. is on comncense 3-Series (E46, E90) 2 10-26-2005 11:04 AM
Rattling Noise in the Morning Lainey 3-Series (E46, E90) 2 10-06-2005 12:25 PM
Some Rattling Noise In 735il When Turning crackerjack 1,6,7,8 - Series and Mini Cooper 0 08-28-2005 02:22 PM
Rattling Noise / Acceleration Revving Noise kln1974 3-Series (E46, E90) 1 12-03-2004 01:10 PM
Rattling noise under hood coolhuh 3-Series (E36) 2 07-15-2004 10:24 PM
