Random misfire codes on all 6 - BMW Forum - BimmerWerkz.com
Old 11-11-2009, 04:45 PM   #1 (permalink)
Car: 1999 328i conv. , 2003 330xi
marcusbingham is on a distinguished road
Unhappy Random misfire codes on all 6
2003 330xi 105,000 miles
The engine was running rough with the check engine light on. I did some of the basics (oil change, spark plugs). I was still rough. Seems the air intake boots were in bad shape so I replaced thouse. At this point, the car is running better going down the road, and idles fine at first, but after an extended idle, it begins to run rough again and throughs on the engine light. The code reader indicates random misfires on all 6 cylinders. Any ideas on where to look next. Is it a vacumn problem and how can i tell?
marcusbingham is offline   Reply With Quote
Old 11-11-2009, 05:46 PM   #2 (permalink)
I wouldn't rule out coils and ignition wires.
Old 11-12-2009, 03:08 AM   #3 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Rotor cap may be on its way out or as WS mentioned leads/coils
Old 11-12-2009, 09:52 PM   #4 (permalink)
update
Thanks for the posts. Here is an update. Vacumn system appears to be sealed up. The coils and wires are giving correct voltage to the spark pulgs. However, the idle problem persists. I get codes from my Peake R5 / FCS -3 code reader as follows:
E3 - O2 sensor adaptation limit Cyl #1-3
E4 - O2 sensor adaptation limit Cyl #4-6
F2 - Misfire - Cyl #5
F1 - Misfire - Cyl #4
My local mechanic claims that the fuel system needs to be reset by the dealship, that it has adapted to runnin gwith the vacumn leaks and needs reset now that they are fixed. Has anyone ever heard of that? Any other suggestions before I take to the dealship 2 hours away?
Old 11-12-2009, 10:30 PM   #5 (permalink)
Maybe you could retest with new O2 sensors/
Old 05-03-2010, 10:03 PM   #6 (permalink)
dcuse32's Avatar
dcuse32 is on a distinguished road
Sounds like you might have a hose leaking air for the compression. I just had the same problem with my car. There was a small hose on the top of the engine under the cover right by the air flow sensor. I had the same codes when i ran a scan. I thought initially it was the ignition coil but i could hear air leaking from that point. Do a sound test first and see if you are leaking any air. If that is not the problem check the coil and follow this video.
dcuse32 is offline   Reply With Quote
Multiple "misfire with fuel cut off" codes could that mean faulty fuel pump? SKIMAN_540i 5-Series (E12,E28, E34, E39, E60) 0 02-22-2009 07:33 PM
misfire k.sidlosky 3-Series (E21, E30) 3 09-10-2008 06:06 PM
E36 1998 3.18i random misfire, lose power check engine light cson 3-Series (E36) 30 06-11-2008 04:42 PM
Misfire? 1980 BMW 323is 3-Series (E21, E30) 1 07-23-2004 12:53 PM
misfire jib 5-Series (E12,E28, E34, E39, E60) 4 07-17-2004 03:24 PM
