I dont see anything wrong with CDC. Im sure others have used it before with no issues. Never seen someone on here that has had an issue with it any way.
Thank you for your interest in CRC products. We would recommend using Synthetic Brake Caliper Grease for your shimmed brake pads. Disc Brake Quiet is ment for usage on non-shimmed brake pads. The Brake Quiet's tackiness will cause the shimmed pad to not work properly. Addtionally the Synthetic Brake Grease will cut down on corrosion on the brakes.
I used the moly lube that came with the pads, It was a very very small amount but if your careful you can make it last.
1000 miles and no noise.
Thanks again.
__________________ A Toast: " To internal combustion and wind in the face"
