question about the headlights - BMW Forum - BimmerWerkz.com
Old 05-05-2004, 07:32 AM   #1 (permalink)
wuballz is an unknown quantity at this point
i just had xenons installed on my 2003 330ci. when i look in the front,each headlight had two fat round lights in it. now that the xenons are in,the outer lights are the ones that light up when i turn the lights on. correct me if im wrong but,i could of swore that the lights thats suppose to come on are the inside ones. i thought the out side ones were brights. i never paid attention to my old lights so im not sure which is the head light and which is the brights. can somebody tell me which bulb is the headlight and which one is the brights? thanks for the help guys.
wuballz is offline   Reply With Quote
Old 05-05-2004, 07:55 AM   #2 (permalink)
mankiks323i's Avatar
mankiks323i is an unknown quantity at this point
outside lights are always driving lights inside ones are for High beams. sometimes cars manufactures will use the highbeams for daytime driving lamps bmw does this because mine are like this
"What happens here stays here" Las Vegas
mankiks323i is offline   Reply With Quote
Old 05-05-2004, 11:14 AM   #3 (permalink)
chris323i is an unknown quantity at this point
i think wuballz is right. i have seen 330's driving around with the inside lights on...
chris323i is offline   Reply With Quote
Old 05-05-2004, 11:20 AM   #4 (permalink)
Originally posted by chris323i@May 5 2004, 11:54 AM
i think wuballz is right.* i have seen 330's driving around with the inside lights on...
no insides are used for Daytime running lamps and highbeams..
Old 05-06-2004, 06:48 AM   #5 (permalink)
sigh...i just got screwed buying a $600 pair of xenons that sucks. anybody have any idea of a good brand of after market xenon lights for a 330ci? i wish i had the money to get the oem parts but alas...its too expensive. i can only shell out about $1000. anybody know of a good after market xenon for bmw's and where to get them at? thanks in advance for all the help.
Old 05-06-2004, 08:18 AM   #6 (permalink)
abajaj is an unknown quantity at this point
used
I believe that the inside lights are the bright ones (others have confirmed this on this forum) - and this is what is happening with you as well.....so why do they suck???
abajaj is offline   Reply With Quote
Old 05-06-2004, 09:07 AM   #7 (permalink)
e36_m3_Turbo's Avatar
lets get this straight. your inside are day time lights, they run without you turning them on. the outside are your normal low beam bulbs. and the inside are also used for high beam
No longer red.
Old 05-07-2004, 06:08 AM   #8 (permalink)
hey,so if you have the factory xenon lights ,are your brights xenon too? or just the regular lights?
Old 05-07-2004, 06:08 AM   #9 (permalink)
Gargoyle69's Avatar
Gargoyle69 is an unknown quantity at this point
i have a question, do all E46 models have daytime running lights? or is that something you have to ask th dealer to activate, that is if it is just something that the OBC has control over?
Silver 2000 323i with sport package
Gargoyle69 is offline   Reply With Quote
Old 05-07-2004, 09:21 AM   #10 (permalink)
Fangs's Avatar
Fangs will become famous soon enoughFangs will become famous soon enough
Yes, all E46 can have the Daytime Running Lights turned on by the dealer. You can also have them turn 'on': Auto Door locking, Car/Key memory, Having the parking lights turn on when you unlock, etc.
It costs about $30, but will vary from dealer to dealer...
<span style='font-size:12pt;line-height:100%'><span style='color:blue'>I don't drive fast,</span> <span style='color:red'>I FLY LOW</span></span>
'99 323i
'02 540i
Fangs is offline   Reply With Quote
Old 05-07-2004, 09:24 AM   #11 (permalink)
Gargoyle69's Avatar
thanks i will check it out.
Old 05-07-2004, 03:19 PM   #12 (permalink)
donutello is an unknown quantity at this point
If you have halogen lights:
- Outside lights are your regular low beam lights.
- Inside lights are daytime running lights, high beam lights and the lights you use to "flash" someone with.
If you have bi-xenons:
- Outside lights are regular low beam lights and your high-beam lights (there's a mirror that converts low-beam to high-beam)
- Inside lights are daytime running lights and "flash" lights. This is because xenon's take longer to get to full intensity and therefore are not suitable to flash someone with.
Daytime running lights are enabled by default on all cars sold by BMWNA but you can ask the dealer to disable them. Daytime running lights are basically the same as your halogen high beams but with about 50% intensity (to save bulb life).
Why do your xenons suck?
donutello is offline   Reply With Quote
Old 05-07-2004, 06:35 PM   #13 (permalink)
my xenons suck because they are not as bright as the factory xenons,also they have a problem with going on and off and weird times.
Old 05-29-2004, 09:51 PM   #14 (permalink)
rosiebmw is an unknown quantity at this point
Hi-
I'm planning on selling a pair (set) of BMW factory xenon lights. Having too much trouble getting it to work on my '03 325i sedan. It's flickering when I start the engine but fine if the engine is off...Not sure what to do. So I'm planning on going back to my stock halogens unless I get some sort of solution.
So if you're interested in purchasing or have tips on how I can get my xenons to work, let me know!!
Thanks! used
rosiebmw is offline   Reply With Quote
Old 05-30-2004, 07:39 PM   #15 (permalink)
KillFox is an unknown quantity at this point
Send a message via AIM to KillFox Send a message via Yahoo to KillFox
post in the buying and selling section
<img src='http://3dwire.net/~matt/killfoxsig2.gif' border='0' alt='user posted image' />
KillFox is offline   Reply With Quote
Quick Question About Two Different DDE's... Red93B3M2W5i 3-Series (E36) 4 10-07-2005 12:19 AM
Headlights Question Black318IS 3-Series (E36) 5 11-07-2004 10:19 PM
E36 headlights fitting question danyal711 3-Series (E36) 3 08-27-2004 10:22 AM
New E46 HID headlights jnleo20 3-Series (E46, E90) 8 07-25-2004 01:06 PM
