Problems With My '99 318i Se... - BMW Forum - BimmerWerkz.com
Old 12-31-2004, 10:37 AM   #1 (permalink)
Renwaldo is an unknown quantity at this point
Hi guys,
Hoping you can help, I've got a few problems with my car.
1. Sometimes, when I try to start my car, when I turn teh key it just 'clicks' in the lock, and doesn't work, However, the radio, headlights etc all work fine. If i simply attach jumpleads to the terminal under the hood it starts immeditely, no problems. Is this the battery? I've had it checked, and the battery is charging, the alternator is giving off 14 volts.
2. Recently, a few things happened to my car all at once. The indicator dash light on the dashboard, and the noise it makes stopped working. As did the cd changer in the boot (the radio says it;s not there), the wipers changing from full mode to intermittent automatically when you stop the car at traffic lights etc..., the other dashboard lights such as full beam, seatbelt not on, door still open etc...
I've checked all the fuses and they're all fine. Is it a loose wire? Has anyone else experienced it?
3. The car is extremely chuggy when i try to start it, regardless of weather etc..., I usually have to press on the accelerator to get it going. Should it be like this?
4. Ever since I bought the car, whenever I press the ASC button near the gearbox the engine warning light comes on the dash and stays on until i press the button again (over 2-3 mintues later). Any ideas what could be wrong with it?
Thanks for any help you can offer me!
Renwaldo is offline   Reply With Quote
Old 01-05-2005, 09:44 AM   #2 (permalink)
Shit - 52 views and no replies... are my problems that bizarre?
Old 01-05-2005, 12:39 PM   #3 (permalink)
1. could be the starter. if old the bendix spring hangs up, and just clicks but doeas not throw the starter gear onto the flywheel. alternatively week battery can give lights, but not enough juice to move the starter (unlikely).
2 and 4. weird ecu problem, coulb be a grounding strip loose somehwere. i really do not know.
3. define better and specify car and tranny type.
Old 01-06-2005, 04:27 PM   #4 (permalink)
Thanks for the reply:
It's a 318i, manual transmission. The problem is when I try to start it, instead of me just turning the key in teh ignition and it roaring into life, it chugs for about 5 seconds before starting. If i don't press on the accelerator, it doesn't actually start at all. Then again, sometimes it starts perfectly. It's independant of the weather, as it happens in the cold and the warm. I am currently having teh fuel filter replaced, so fingers crossed.
As for the ecu thing, I'm thinking this as well. It's definately not the fuses, I've had a garage look over it for 2 hours now and they can't find the problem with it. Will the dealership be able to find it pretty quickly with their diagnosic computers? Any idea on a price for an ecu replacement?
As for teh clicking when it starts, I don't think it's a weak battery, because to test this I put the radio on and left the lights on for a good 20 minutes, and none of them went off or weakened. Plus, the battery is being charged by the alternator. I'm thinking starter motor - any ideas again on price / labour for fitting one?
Thanks
Old 01-06-2005, 04:52 PM   #5 (permalink)
sean's Avatar
sean is an unknown quantity at this point
Send a message via AIM to sean
about the asc button, is it the warning light, or the traction light between the guages. if it is the traction light that is supposed to stay on as long as the asc is turned off
<img src='http://img.photobucket.com/albums/v146/318ibmw318i/the_sig.jpg' border='0' alt='user posted image' />
signature designed by crisby_E30
<span style='font-size:8pt;line-height:100%'><span style='color:blue'>
<span style='color:red'>Chairman</span> of the &quot;BMW-Forums...Cant hack it? Go Whack it... &quot; Mafia...&quot;We'll take your shoes&quot; </span></span>
sean is offline   Reply With Quote
Old 01-06-2005, 09:32 PM   #6 (permalink)
brute force replacement of ecu is likely a waste of money. have bmw or a competent shop check fault codes. do it as soon as possible after the malfunction, because start/stop cycles erase the codes.
number 3 and possibly your start problems sound to me like the mixture is screwed up. so this could be:
1. mass air flow sensor.
2. temp sensor.
3. o2 sensor.
all can be checked for spec before replacing, especially mass air flow cos it is expensive to replace.
before all this: take out plugs and look at them: soot, cracks, incorrect gap etc.
fuel filter is very unlikely, so is the pump. this stuff usually will give problems at full throttle, not start.
Old 01-06-2005, 09:33 PM   #7 (permalink)
318i: where are you geographically, we aint' got no 4 cylinders here in the us in the e46 cars...
Old 01-07-2005, 06:29 AM   #8 (permalink)
I'm in the UK. - the light is the warning light.
Old 01-07-2005, 08:52 AM   #9 (permalink)
you do need to check this car for fault codes. bmw or a reputable shop, i'd email the "car" editorial staff to get a name close in your area.
My 1994 318i has some problems itbestrider 3-Series (E36) 14 10-12-2005 10:46 AM
BMW 318i 92Model E36 Starting Problems deanbelich 3-Series (E36) 7 09-21-2005 11:41 AM
318i Radiator Problems Numark318i 3-Series (E21, E30) 3 07-25-2004 10:17 PM
