Problem with starting when its cold.. Whats the reason? - BMW Forum - BimmerWerkz.com
Old 01-18-2012, 07:32 PM   #1 (permalink)
Car: BMW 04 330i
Monique626 is on a distinguished road
Angry Problem with starting when its cold.. Whats the reason?
Annoying when I'm somewhere and it wont start!! uhhhhh
Monique626 is offline   Reply With Quote
Old 01-18-2012, 09:03 PM   #2 (permalink)
Car: 2002 BMW 330xi
dance41nancies is on a distinguished road
Is the check engine light on? If so, do a scan. Might be a camshaft position sensor...?
dance41nancies is offline   Reply With Quote
Old 01-19-2012, 08:19 AM   #3 (permalink)
Car: 1989 BMW 535i
rivroshaun951 is on a distinguished road
1. When is the last time you pulled and inspected your spark plugs?
2. How old is your Battery.
3. How cold are we talking? California cold or Canada cold.
4. What kind of gas are you using?
If the car starts normal when it's warm I would not suspect a sensor. Think about what the cold weather can effect. "Voltage". As temp go down. Voltage goes down. I would start by checking the battery. If all is good and since the car does start I would move to looking at small tune up items. spark plugs etc.
rivroshaun951 is offline   Reply With Quote
Old 01-19-2012, 10:12 AM   #4 (permalink)
jimmythepie's Avatar
Car: 98,328i
battery first,then move on
jimmythepie is offline   Reply With Quote
Old 01-19-2012, 12:03 PM   #5 (permalink)
Car: 2005 330i Convert
kerryf is on a distinguished road
If battery is marginal, might also want to check ground connection. Cold will affect resistance.
kerryf is offline   Reply With Quote
Old 01-20-2012, 08:02 AM   #6 (permalink)
Car: 1989 BMW 535i
Oh how could I forget Oil. what type of oil are you using. this will also cause start up issue if not correct for your vehicle and conditions.
Old 01-20-2012, 09:58 AM   #7 (permalink)
Car: 1995 Bmw E36 320i, E87 Mags,Angels
DSP543GP is on a distinguished road
Hi bimmer lovers
I am also experiencing cold hard start with my e36 320i 95 model, the plugs (bosch) are newi also use shell unleaded 93 or 95 v power, oil is engen 20w50, battery new 652, the car start fine when once started but when cold it would want to start and won't catch up. The plugs gets wet with fuel, the coils and plugs would spark even though they glow spark. At times I would take my spare ignition coil with spark plug and put them on the engine cover, it would hesitate to start and finally start. What am I missing here, the dme is good, there's no error codes beside tank ventilation error, my car never showed any cel light and the sensors (crank and cam are new), any idea? I'm in south africa and my car doesn't have lambada sensor, pls help
DSP543GP is offline   Reply With Quote
Starting Car When Cold Cod 3-Series (E36) 1 12-18-2006 01:09 PM
problems starting car when cold... VLAD_325is 3-Series (E36) 8 09-12-2005 08:08 PM
Problem When Cold Starting DOn_MEGA 3-Series (E36) 7 12-20-2004 03:55 PM
Cold Starting _1634_ 3-Series (E36) 2 09-07-2004 04:03 PM
Cold Starting CaptainEL 5-Series (E12,E28, E34, E39, E60) 3 01-06-2004 12:45 PM
