Ordered my 2004 325cic in September, took delivery exactly one month ago, having what I think is a problem with the window control. When I first bought the car, the one-touch button could be used to lower all four windows at one time. If I pressed hard on the button, the auto-lower kicked in and the windows would continue to lower even if I released the button. The one touch button could also be used to raise all four windows, but no auto-up feature. About two weeks ago the driver's side window stopped responding to the one-touch button when I tried to raise the windows (one touch still worked for all four lowering). Then about four days ago the one touch stopped working for raising the passenger side, too. So now all the one-touch will do is raise the back two windows (and lower all four).
I asked the tech at the dealership about it and he said that was a safety feature so that nothing would get trapped in the window, ie the one touch was only supposed to raise the back two all along. He couldnt tell me why it worked on all four for the first few weeks.
I know that cant be right, especially since when I use the key in the door lock to lower the top and windows, it works fine. But when i use the key to raise the top, it wont raise the driver and front passenger windows. It makes no sense that you would step out of the car, close the top with the key in the door lock, then have to climb back into the car, put the key in the ignition, raise first the driver window, then the front passenger window, then exit the car. ghead
Any ideas?
I would read the owners manual first and read the guidelines as to what it will do, then if it is supposed to work like you say, I would go and show them that...I think he might be bs'ing you about the safety feature...
__________________ -1998 BMW 540i6(Axis Penta 20's,M5 shadow grilles,trunk lip,led tails,oem front lip,PIAA lighting)
-2002 Cadillac Escalade(Zinik Luina 22's,OEM HID upgrade)
Were your doors open when you were trying to use the one touch? I doesn't work with the door open, I was trying to raise the windows in my 2003 325i with the door open using the one touch, it woudn't work. When I closed the door it was fine. Hope this helps.
The "toll" function doesn't work for the up position, so your kids or dogs don't get their heads caught in them. If you manually hold it up, they should all go up, though.
I don't know off hand what would cause it. You haven't spilled any soda in the switch block have you?
Some of the 3 series have a recall for the general module, which requires the module replacement. This is because the anti-trap funcition possibly would not work, but I don't know if it applies to the convertible.
Take it in to the dealer, sounds like the driver's door module.
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
