Please Help !! Tires fits or not? - BMW Forum - BimmerWerkz.com
Old 07-08-2009, 08:39 PM   #1 (permalink)
Car: 03 Bmw 325i
fasaavedra4 is on a distinguished road
Hi everyone,
i need some advice here,
i have a 03 BMW 325i, their regular tires are 205 55 16 , and i have a guy selling me a 5-Series wheels with tires 225 50 17 ( really nice wheels ).
He said to me they will fit, however at tirerack.com when it shows the size for an 03 3series tires with rim 17 it says 225 45 17
So, do you think the 225 50 17 fits my 03 325i ?
Please let me know asap.
Thanks to all
fasaavedra4 is offline   Reply With Quote
Old 07-08-2009, 09:58 PM   #2 (permalink)
Mr. Clean
BimmerE39's Avatar
It might be a tight fit. Also, what 5-series are the wheels coming from. If it's an E39 I know the wheels won't fit because the wheel hub size differs from the E46 and E39. You will need to buy hubcentric rings in order to make them fit. Either way, the profile of those tires on 17 sounds like you may have a problem fitting it in the wheel well of the E46. 225/45 is probably a safer size.
Old 07-08-2009, 10:07 PM   #3 (permalink)
Car: 03 Bmw 325i
Hey, thanks for your answer and help.
Based on the pictures i have of the wheels, i would say is a E60 wheels.
here is the link where you can see the tires:
17" OEM BMW Wheels NEED GONE NOW!!!(RUN FLAT TIRES!!)
Please let me know what you think, iu really do like them
Thanks.
Old 07-08-2009, 10:16 PM   #4 (permalink)
Mr. Clean
BimmerE39's Avatar
You're set with the hub size then. The E60 is 72.6 mm and the E46 is the same at 72.6mm. The only thing I'm not so sure about is the offset between the E46 and the E60. I know they're going to be different but I'm not sure by how much. I'm afraid the difference might be too different. Let's see if someone else chimes in on this.
Old 07-08-2009, 10:49 PM   #5 (permalink)
Car: 03 Bmw 325i
once again for you anwer.
are you sure the hub sizeon the E60 is 72.6 mm , for some reason at Lug Pattern Reference Guide LugPattern.net , it shows like it is 74.1 mm. What do you think ??
Im still undecided wheter to get those tires.....what a problem.....
Old 07-08-2009, 10:58 PM   #6 (permalink)
Mr. Clean
BimmerE39's Avatar
I know for a fact the hub bore on the E60 is 72.6. The E39 is the only BMW that had a 74.1mm hub bore. BMW went back to the smaller hub after the E39. Even so, I'm still not sure the E60 wheels will properly fit your E46 and I'm 95% sure those tires are going to be too big to fit inside of the wheel well.
Personally, I'm not a huge fan of BMW factory wheels or any factory wheel for that matter. I think if you want to change the wheels on your E46 you should look at some after market wheels that are properly dimensioned to fit your E46. It might be a little more expensive but I think you'll be happier in the long run. Just my two cents.
Old 07-08-2009, 11:01 PM   #7 (permalink)
Car: 03 Bmw 325i
definetively , you are right.
Thanks for you advice.
I just placed a new post, your comment is valuable.
Thanks
Old 07-08-2009, 11:03 PM   #8 (permalink)
Mr. Clean
BimmerE39's Avatar
Sure, no problem.
Nothing Fits! M3Convert M-Series (M1, M3, M5, M6) 8 07-30-2007 01:00 PM
FS: MM 19" Wheels and PS2 Tires (fits E39) SnidelyWhip Wheels and Tires 1 05-05-2006 10:48 PM
E60 545 wheels and tires, fits E39, E34 BimmerTech24 Wheels and Tires 0 01-13-2006 09:16 AM
E60 545 18" wheels and tires fits E39, E34 BimmerTech24 Classifieds Sell & Buy 0 01-12-2006 10:09 AM
What Fits with no Fuss BlkCofy 5-Series (E12,E28, E34, E39, E60) 4 03-09-2004 12:44 PM
