PLEASE HELP PROBLEM W/My 330ci - BMW Forum - BimmerWerkz.com
Closed Thread
Old 12-07-2007, 01:38 AM   #1 (permalink)
Christian.park07 is on a distinguished road
Ok guys/ girls... i really need help here. I just joined the E46 class crew.=) But im having this problems with my car already. Please help if you have ever heard of such a problem.
It happens every now and then... first make a model. Bmw 330ci 2001 auto.
When im at a stop, sometimes i mean sometimes the car stalls out and stops running. I have to stick it back in Neutral and then start the car again. Sometimes it has a hard time starting and when it does, i stick it back into drive and accelerate it shuts off again. This happens every so often.
Also when im driving it sounds like the intake is trying to suck alot of air which gets louder and then accelerates hard. like lagg or some what.
anyone heard of this problem or even experienced this problem please help me! i dont want to spend thousands of dollars taking into BMW and them ripping me off.
Comments feedback would be great Thanks guys/gals
Christian.park07 is offline
Old 12-07-2007, 08:12 AM   #2 (permalink)
chinonca's Avatar
chinonca is on a distinguished road
Stall problem
First of all do you have a check engine light on??? Next when was the last time you did a tune up!?
chinonca is offline
Old 12-07-2007, 08:13 PM   #3 (permalink)
bmw
Um no i dont have a check engine light on. I just have a service engine check light that came on. Im kinda new to BMW's so i dont really know if they is considered check engine light. Last time i did a tune up was 130xxx.
Old 12-07-2007, 08:20 PM   #4 (permalink)
chinonca's Avatar
you need to get that service engine light checked out to see what code the ecm is logging, after you find out the code you will have an idea of what is going on with her!
chinonca is offline
Old 12-08-2007, 10:30 PM   #5 (permalink)
m2fm2 is on a distinguished road
you need to get the code read to help pin pont the problem. hard to diagnose over the web. but off hand it sounds like a vacuum leak or maybe a bad MAF?
m2fm2 is offline
Old 12-08-2007, 11:55 PM   #6 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
bad spark plug wire(s) maybe shorting? plugs? coil could be dieing?
1992 318i Coupe parts car
I am Captain Obvious
AlpineSixAndSeven is offline
Old 12-09-2007, 02:09 AM   #7 (permalink)
WOT in Reverse
jllphan's Avatar
is it ever tough to start? or does it start every time? if so, it's probably the cam sensor. if not, it could be a lot of things. best to take it to your local tech and have them read your fault codes, should give you some indication of the issue. hope this helps
jllphan is offline
Old 01-02-2008, 05:17 PM   #8 (permalink)
PIMPO is on a distinguished road
The only thing i can think of with the intake noise is that the fan clutch can be getting stuck!
If so, it could break your fan blades off then break pretty much everthing in the front of the engine.
Coolant systems suck for e46
happened to me and was very expensive to fix.
PIMPO is offline
Old 10-13-2010, 06:55 AM   #9 (permalink)
Car: 04 330ci supercharged, lowered
blown330ci is on a distinguished road
Check for leaking intake gasket.
blown330ci is offline
Old 10-13-2010, 09:08 AM   #10 (permalink)
The OP is from 2007
witeshark is offline
Closed Thread
Desperately Need Your Help: BMW325i "Service Engine Soon" light problem CNMB250 3-Series (E46, E90) 4 12-19-2007 06:26 AM
330Ci Power loss Blue Ninja 3-Series (E46, E90) 6 02-18-2007 08:26 PM
E34 trans prog problem exacerbated electronblue 5-Series (E12,E28, E34, E39, E60) 5 03-02-2006 10:07 PM
330CI LED Tail light conversion problem kwoktoa 3-Series (E46, E90) 2 02-05-2004 07:47 AM
