please help - BMW Forum - BimmerWerkz.com
Old 03-14-2004, 07:59 PM   #1 (permalink)
we had some complaining about the squeaks in the back of the car. mine just started squeaking sort of from the back seat, definitely inside. worst on bumps in turns, and much worse in cold weather. what gives ?
peter 330iPP
Old 03-16-2004, 06:27 PM   #2 (permalink)
EXtech's Avatar
do you have the access door in the middle of the backseat? Could be the latch. Could be the package tray/leather or leather to leather. Could also be the rear shock mounts. Those are notorious for sounding like they are on the inside. Do you have the Harmon Kardon system with the rear sub? Could be the rear sub assembly rubbing against the rear deck/package tray
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 03-19-2004, 08:46 AM   #3 (permalink)
thanks man.
i will investigate all of these, and report about the sccess of the endevour.
peter
Old 03-19-2004, 08:47 AM   #4 (permalink)
btw, yes on all of your questions.
Old 03-19-2004, 07:44 PM   #5 (permalink)
bmwtech332ti is an unknown quantity at this point
sway bar bushings will squeek like this. I usually put teflon tape around the sway bar and then reistall the mounts. This works better than lubing.
bmwtech332ti is offline   Reply With Quote
Old 03-21-2004, 09:38 AM   #6 (permalink)
egalley is an unknown quantity at this point
I believe I'm experiencing the same sqeek as you. Do you have the rear sunshade? I do, and I think it's comming from that. I'd like to know if you manage to stop the squeek.
egalley is offline   Reply With Quote
Old 03-21-2004, 07:48 PM   #7 (permalink)
dmontic71 is an unknown quantity at this point
The back of my 02 325ci definitely rattles when I go over bumps- I cant seem to find any source- it seems like the read deck lid or something... By the way what is a sway bar?
dmontic71 is offline   Reply With Quote
