I posted before about the problem with my engine. Anyways, I have a 2003 325Ci manual and a week ago my engine shut down and the car wouldn't move. I had it towed to the BMW dealer and after 5 days of diagnosing they found out that the pistons were shot. The dealer also told me that the computer said that the car was reved up too much (redlined) and that's what caused the problem. Now, I don't usually redline my car, maybe once in a blue moon, but still, it's a brand new car and it should be able to take a few redlining. Therefore, the dealer told me that the warranty doesn't cover it. What should I do? Please help.
Very simple..it's called a 'break in' period which I think you didn't follow..3 rules tp follow:1 don't go too fast (above 65 speed limit), 2 don't rev too high, and 3 don't run on cold engine tempertures..
Other break in steps are typical..upto 500 miles, keep the rev under 3000 rpm..upto 700 miles, keep the rev under 3500rpm..Upto 900 miles, keep the rev under 4000rpm..after that keep the rev under 5000 rpm until you hit 1500miles..after 1500miles, you can do anything you want!!
looks like you need to get a new motor my friend. that is gonna cost ya. i am not sure but you may be able to get the motor from the M3
__________________ Member 150+ MPH club
Member of the 3-Pedal club
Memebr BMW FORUMS V1 CLUB
Yeah, but the first guy told me that it was the factory's fault and the piston heads weren't damaged so the problem couldn't have come from reving the engine to high.
Originally posted by mikefliggity@Aug 4 2003, 07:22 PM Yeah, but the first guy told me that it was the factory's fault and the piston heads weren't damaged so the problem couldn't have come from reving the engine to high.
But did you follow the break in rules?? Yes or no??
Originally posted by Ski+Aug 4 2003, 05:47 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Ski @ Aug 4 2003, 05:47 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-mikefliggity@Aug 4 2003, 07:22 PM Yeah, but the first guy told me that it was the factory's fault and the piston heads weren't damaged so the problem couldn't have come from reving the engine to high.
But did you follow the break in rules?? Yes or no?? [/b][/quote]
To tell you the truth i dont remember but i think so
Originally posted by mikefliggity+Aug 4 2003, 05:54 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (mikefliggity @ Aug 4 2003, 05:54 PM)</td></tr><tr><td id='QUOTE'>
To tell you the truth i dont remember but i dont think so [/b][/quote]
i dont think its fair for bmw to blame you, every time i go to a bmw dealership to test drive cars the dealer always keeps the engine pegged on the rev limiter to show off the cars power, performance, etc. so if you bought the car off the lot, even if it had under 50miles, it couldve been abuse from a couple test drives that caused engine failure that early on. one time i went to test drive a 330Ci with my dad that had 10miles on the odometer and the salesman still didnt hesitate to redline 1st 2nd and 3rd.
That's a very good point MrM3 but hard to prove at this point..If I was you Mike I'd call BMW regional representative and prove your case and tell them that the sales team didn't inform you on how the correct way to break in your ride..if that indeed is the problem..nobody is 100% sure on the internet, this is just theories posted here..
Originally posted by MrM3+Aug 4 2003, 06:01 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (MrM3 @ Aug 4 2003, 06:01 PM)</td></tr><tr><td id='QUOTE'>
i dont think its fair for bmw to blame you, every time i go to a bmw dealership to test drive cars the dealer always keeps the engine pegged on the rev limiter to show off the cars power, performance, etc. so if you bought the car off the lot, even if it had under 50miles, it couldve been abuse from a couple test drives that caused engine failure that early on. one time i went to test drive a 330Ci with my dad that had 10miles on the odometer and the salesman still didnt hesitate to redline 1st 2nd and 3rd. [/b][/quote]
o wow. I'm going to get a lawyer if the dealer decides to void my warranty. This is ridiculous, the car is brand new and also how can the pistons break by reving the engine too much, i just don't understand that.
You have two opposite functions to perform at break-in:
1) Apply enough pressure to the piston rings (via high-load) to have them expand and match the cylinder bore (in fact, they both wear a bit and fit each other). This also applies to valve to valve-seat interfaces and all plain bearings.
2) Avoid excessive heat that would cause distortion that will prevent these parts from mating.
BMW advise not to exceed 5,000rpm for the first 600 miles, for good reason, to prevent heat-seizures or cylinder scoring. This allows you to travel at around 75mph in top gear, throttle on - throttle off, which is fine for breaking in and doesn't require too much throttle restraint. My neighbour who is a mechanic for BMW, said if someone admitted they'd been red-lining it before 600 miles had been covered, they wouldn't be covered for any warranty claims for engine problems. Surely it's best to follow what BMW advise, after all it's only for 1,200 miles total before you can really wring its neck, if that's the way you wish to ride.
The main idea is to exercise the engine like you would a muscle. Build up slowly and don't do the same thing for too long. Yes, you want to keep engine revs down and increase gradually, but also you want to run a variety of engine and gearbox routines. Run City traffic for half an hour then country lanes for a couple of hours, then finish with maybe 15 minutes of mixed steady and fast motorway. Repeat until you've done the miles. Running motorways at 100 kph to do the distance will shorten engine life almost as much as not running in at all.
Here is an interesting statement from Jeremy Hall, a principal engineer in Honda's engine design department. He is quoted (page 61 of the July issue of Popular Science) as stating that the stress on an engine at 9,000 rpm is double that at 8,000 rpm. Something to think about as you wind your engine to redline.
of course RPM's differ from each engine. but set guidlines are there for a reason
hopefully I can provide some inspiration. Having been a BMW dealer tech for many years, I have run into problems like this and have seen others as well. Heres the game plan: take a deep breath, take a stiff drink and walk into the dealer and give em hell . Get BMW North America involved and be persistent . If that doesn't work, "go to the mattress"
Seriously though, you didn't mention exactly what the dealer said happened to the pistons. Did they give you any more explanation? When did the diag show the over rev was? If they can't tie the over rev to when the engine quit, then there's not much of a leg to stand on. When did the engine shut down? did it just die one day out of the blue or did it shut down after running the crap out of it? Did it smoke or knock? Typically on an over-rev the valves take a beating by the pistons. This is usually evident by marks on top of the pistons and bent valves. However, if the motor is not properly "broken in" , an engine typically doesn't allow the rings to "seat" creating excessive blow by and oil consumption with an eventual loss of power and performance and more. With the motor torn down and PROPERLY inspected by a qualified technician, it can easily be determined what happened and how. Have the regional rep for your area from BMW NA meet with you and the service manager at the dealer in front of the car and disassembled engine and stand your ground. Ask to see the damage and ASK QUESTIONS. I certainly hope you're not trying to pull one over on the dealer and you didn't in fact abuse the motor. If you can't change their minds, give 'em the good ole and pay the bill. Good luck !!
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
