| So you couldn't afford an M5 because of your budget, however you would be able to spring for an M5 motor and trans? I can't tell you how much you would find these for outside of a dealer but I can tell you that the M5 shortblock used to cost ~$10-11,000 (dealer cost). Factor in a tranny (~ 5k or so), maybe a custom driveshaft, heavier suspension pieces (added weight) and all of the necessary hardware and misc. pieces plus labor... you'll be spending at very minimal $20-23,000. That's if everything even fits. Get yourself a supercharger and DME programming. It's much cheaper, reliable and will add a respectable amount of power. Then save up some money and later on do some head work and cam swap.
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
STETT Performance Official Grand Opening BMW Meet, May 6th 11A-3P -- Music, Food, Drawings and Tons of BMW's go to http://206.123.107.13/stett and register.. it's FREE |
