Passenger Window Issue - Regulator? - 2005 325xi - BMW Forum - BimmerWerkz.com
Old 09-28-2009, 07:07 AM   #1 (permalink)
Car: 2005 BMW 325xi
rstier is on a distinguished road
Hi,
My passenger window is having issues going up on my 2005 325xi. It also has excessive side to side play. Going down it is fine but going up it crawls and usually needs to be helped by hand. Does this sound like a broken regulator or just a loose part (e.g. roller, etc)? If it is the regulator, is that difficult to change?
Thanks!
Ron
rstier is offline   Reply With Quote
Old 09-28-2009, 10:35 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Best thing to do is remove the door card and sound proofing and investigate, BMW uses a lot of plastic parts on their window mechanisms.
Old 09-28-2009, 09:45 PM   #3 (permalink)
otisol31 is on a distinguished road
Easy fix
I had the same problem on my 2001 330i.....both drivers and passenger side windows. I found the web site below which explains how to repair the regulator with ty-wraps and I just "fixed" both windows today. I'm not sure how long it will last, but it was worth trying. The window regulators are pretty pricey.
Whether you try the ty-wrap repair or just replace the regulators, it's a relatively easy job if you have some mechanical ability.
On thing to note: Disconnect the battery before unpluging the side airbag. Do not reconnect the battery with the airbag module unplugged or the airbag light won't go out and you'll need a scan tool or dealer to reset it. That was the one mistake I made. That means you'll need to get the window in the proper position to remove the 2 bolts that hold the glass to the regulator before disconnecting the battery and the airbag.
E46 Window Regulator
If anyone in Southern CT has or knows of someone with an SRS scan/reset tool with a 16 pin connector that they would let me use to reset the airbag light, it would be greatly appreciated.
otisol31 is offline   Reply With Quote
Old 09-29-2009, 09:20 AM   #4 (permalink)
I am surprised that BMW makes a window so cheaply. For a car that is built so solid otherwise, it is amazing how these things break so easily.
FCP Groton
877-634-0063 | info@fcpgroton.com
FCP Euro - European Car Parts Specialists
FCP Import - Import Replacement Car Parts
FCPGroton is offline   Reply With Quote
Old 09-29-2009, 10:36 AM   #5 (permalink)
Car: 2000/BMW/323i
kohlers is on a distinguished road
The previous owner of my 2000 323i (with 100.000 miles) replaced the passenger regulator with a $60 aftermarket that broke shortly after I got the car a month ago. The plastic that holds the wire at the window was soft and cheap and that is the part that broke. I got a OME for $117 from rmeurope and installed it with the help of the previous owner without disconnecting battery and airbag. Works fine now.
kohlers is offline   Reply With Quote
Old 09-29-2009, 08:50 PM   #6 (permalink)
Car: 2005 BMW 325xi
Good info, thanks to all who replied!
I'll do some door surgery and take a look at what's going on. That link provided should help.
2005 325xi for sale bmwsuzy159 Cars For Sale 0 01-13-2008 05:16 PM
For Sale 2005 325xi bmwsuzy159 Classifieds Sell & Buy 0 01-08-2008 01:48 PM
2005 325xi bmwawd 3-Series (E46, E90) 0 05-01-2005 08:17 PM
2005 325xi bmwawd 3-Series (E21, E30) 0 05-01-2005 07:50 PM
2005 325xi - How Much Below Msrp cmohan 3-Series (E46, E90) 0 12-21-2004 03:04 PM
