» Sponsors
» Sponsors
Old 07-05-2004, 09:04 AM   #1 (permalink)
Photos: 0
Infinity is an unknown quantity at this point
Hi,
I have a E46 328i. Recenlty my brake warning like came on to indicate my pads were low (the orange light), so I got them both my front and rear pads replaced as they were both very low and also both sensor, but the warning light still come on!
Does any one know what could be wrong or is there a way to reset it the sensors? I have been driving the car with the the warning light still on.
All parts were bought from a BMW main dealer.
Thanks
Infinity is offline   Reply With Quote
Old 07-05-2004, 09:08 AM   #2 (permalink)
TMac325is's Avatar
Photos: 0
90% of the time that means you just need to replace the brake pad sensors. im not sure if the computer needs to be reset for that or not.
i know the brake pad sensors were a problem on the e36 if you bought aftermarket brakes
Old 07-05-2004, 09:17 AM   #3 (permalink)
Photos: 0
I did change both the front and rear sensors with original BMW sensors, but still no luck! Both front and rear pads were also changed with original BMW parts.
Old 07-05-2004, 11:24 PM   #4 (permalink)
CiscoKid's Avatar
Photos: 0
unplug the negative terminal on the battery for a few ans ee if that does anything... make sure you have ur radio code
Old 07-06-2004, 12:29 AM   #5 (permalink)
Photos: 0
bearing01 is an unknown quantity at this point
Try turning the key to position 1 before starting the car.. and pump the brakes. leave it for a few seconds. This could get rid of the the light... and then it may not. I would think that the light will go away on its own after a while.
You can disconnect the battery. The only problem with that is that it resets the ECM memory and you essentially start with a new computer. The car has to re-learn its settings... therefore expect the car to handle and feel different for a few days.
I would drive around for a few days before resorting to pulling the battery.
John
bearing01 is offline   Reply With Quote
Old 07-07-2004, 12:50 PM   #6 (permalink)
Mach 5's Avatar
Photos: 0
Mach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond repute
Turn the key to the run position but do not start the car. Teh lights in the dash will begin to go out. After about 20 sec the brake warning light will go out.
Ben
&quot;It's not because I'm an aggressive driver, it's because I'm an idiot&quot; actual quote from my wife.
Mach 5 is offline   Reply With Quote
vB code is On
Brake Light Circuit Warning (again) Stamey 3-Series (E21, E30) 11 03-05-2005 07:05 PM
Annoying Brake Light Circut Failure NyteRyda 3-Series (E36) 14 01-21-2005 09:14 AM
Brake Light Circuit Warning? Laker 3-Series (E36) 10 08-31-2004 11:00 PM
Brake Lining warning Light Jefbrunton 5-Series (E12,E28, E34, E39, E60) 5 01-07-2004 04:07 PM
After tail-light upgrade, left brake light is gone mostwired 3-Series (E36) 3 11-26-2003 05:13 PM
