overheating when in traffic or stoping - BMW Forum - BimmerWerkz.com
Old 03-11-2011, 02:59 PM   #1 (permalink)
alexs83id is on a distinguished road
My car 328ci 2000 has some issues , the car always showing overheat when i drive in traffic . First , I changed the electric fan that bought on ebay but still show the same problem . what i would like to know is what should i changes the thermostat , pump or the hose.. I don't want to guess. please help here i wasted money already!!
( when I drive on the freeway which is fine ),,
the fan that i bought does not comes with the electrical stuff so i just replace it with the old one ..
alexs83id is offline   Reply With Quote
Old 03-21-2011, 07:36 PM   #2 (permalink)
bmwtech1 is on a distinguished road
Sounds like you need a water pump (starting to fail), to test this when the car is cold take off the expansion tank cap and run the car, you should see a stream of coolant going back into the tank, if you accelerate the stream should go much faster (you will need a 2nd person to check this on acceleration), sounds like you probably won't have any flow at idle in your case which is no good. Hope this helps
bmwtech1 is offline   Reply With Quote
Overheating At Idle In Traffic wcre34 3-Series (E36) 7 08-15-2005 09:58 AM
Overheating When Stuck In Traffic bmw323inewbie 3-Series (E36) 12 12-16-2004 06:56 PM
Engine overheating in traffic zlac109 3-Series (E36) 12 05-02-2004 08:14 PM
stoping the beeping alanh 3-Series (E21, E30) 10 03-25-2004 07:14 PM
