» Sponsors
» Sponsors
Register Home Forum Active Topics Gallery / Showroom Garage Search Today's Posts Mark Forums Read
BimmerWerkz.com is the premier BMW forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 08-06-2005, 02:13 PM   #1 (permalink)
delboy is an unknown quantity at this point
can someone please help. ive got a 318i v-plate that will not stop overheating. it will over heat while i am driving, even on the motorway, or when its idling in the drive. does anyone know about the fans, mine doesn't seem to be drawing any air, there seems to be no drag. please can someone help. used
delboy is offline   Reply With Quote
Old 08-06-2005, 02:35 PM   #2 (permalink)
storme's Avatar
storme is an unknown quantity at this point
are all your belts still in place????? 1 of them frives the water pump...
also,,look for a kinked pipe or somthing similiar
do you still get heat from the heater????
turn it on full when the car starts to o ver heat
if there is no heat,,,your thermostat has gone kapput
visit me at <a href='http://www.storme.co.uk' target='_blank'>www.storme.co.uk</a>
visit me at http://www.janspeed.com
storme is offline   Reply With Quote
Old 08-06-2005, 06:10 PM   #3 (permalink)
Is the fan turning with engine running, or with AC on? If not, disconnect the electrical connector/s at fan temp switch and then with iginiton on run jumper wirs from battery (+/-) to the fan swithc temp switch and see if the fan runs (this troubleshoots the fan motor and relay or resistor).
Old 08-07-2005, 06:19 AM   #4 (permalink)
[snapback]367810[/snapback]
lots of heat from the heater, all belts in place, seems very odd&#33;&#33;&#33;&#33;
Old 08-10-2005, 07:10 PM   #5 (permalink)
nathan56989 is an unknown quantity at this point
Not odd at all at the dealer. due to the water pump impellar being made of plastic (german technology) they come completely off the pump shaft and crumble. if your going to fix this oyurself replace the thermostat, thermostat housing and the water pump. along with all the o rings.
nathan56989 is offline   Reply With Quote
Engine Overheating doughnutboy 3-Series (E36) 11 06-13-2005 02:10 PM
Overheating Problem & Stiff Radiator Hose ?? viluve 3-Series (E36) 6 10-30-2004 01:39 PM
Overheating 1992 325iC sneaksta 3-Series (E36) 0 09-09-2004 07:05 PM
Overheating StevO 3-Series (E36) 4 09-07-2004 04:52 AM
