Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 08-06-2005, 03:13 PM   #1 (permalink)
Photos: 0
delboy is an unknown quantity at this point
can someone please help. ive got a 318i v-plate that will not stop overheating. it will over heat while i am driving, even on the motorway, or when its idling in the drive. does anyone know about the fans, mine doesn't seem to be drawing any air, there seems to be no drag. please can someone help. used
delboy is offline   Reply With Quote
Old 08-06-2005, 03:35 PM   #2 (permalink)
storme's Avatar
Photos: 0
storme is an unknown quantity at this point
are all your belts still in place????? 1 of them frives the water pump...
also,,look for a kinked pipe or somthing similiar
do you still get heat from the heater????
turn it on full when the car starts to o ver heat
if there is no heat,,,your thermostat has gone kapput
visit me at <a href='http://www.storme.co.uk' target='_blank'>www.storme.co.uk</a>
visit me at http://www.janspeed.com
storme is offline   Reply With Quote
Old 08-06-2005, 07:10 PM   #3 (permalink)
Photos: 0
Is the fan turning with engine running, or with AC on? If not, disconnect the electrical connector/s at fan temp switch and then with iginiton on run jumper wirs from battery (+/-) to the fan swithc temp switch and see if the fan runs (this troubleshoots the fan motor and relay or resistor).
Old 08-07-2005, 07:19 AM   #4 (permalink)
Photos: 0
[snapback]367810[/snapback]
lots of heat from the heater, all belts in place, seems very odd!!!!
Old 08-10-2005, 08:10 PM   #5 (permalink)
Idle Member
Photos: 0
nathan56989 is an unknown quantity at this point
Not odd at all at the dealer. due to the water pump impellar being made of plastic (german technology) they come completely off the pump shaft and crumble. if your going to fix this oyurself replace the thermostat, thermostat housing and the water pump. along with all the o rings.
nathan56989 is offline   Reply With Quote
vB code is On
E36 Overheating / Head Problems Sean Duggan 3-Series (E36) 7 10-05-2005 06:45 AM
Engine Overheating doughnutboy 3-Series (E36) 11 06-13-2005 03:10 PM
Overheating Problem & Stiff Radiator Hose ?? viluve 3-Series (E36) 6 10-30-2004 02:39 PM
Overheating 1992 325iC sneaksta 3-Series (E36) 0 09-09-2004 08:05 PM
Overheating StevO 3-Series (E36) 4 09-07-2004 05:52 AM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
