Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 08-01-2005, 05:16 PM   #1 (permalink)
Photos: 0
dand65 is an unknown quantity at this point
I have a 2003 3 series and it was overheating. The first thing I change was the thermostat. did not fix the problem. Some advice that I have recieved is that you must use the red coolant, does this make a difference. What other parts on the car can cause overheating. Thanks
dand65 is offline   Reply With Quote
Old 08-01-2005, 05:36 PM   #2 (permalink)
storme's Avatar
Photos: 0
storme is an unknown quantity at this point
are all your belts in place,,,???? if one is missing this will overheat because the water pump isnt turning
did u put the thermostat in the right way round???
did you do a "reverse" flush of the rad??
did you bleed the system ??
is there a kinked pipe??
etc etc
visit me at <a href='http://www.storme.co.uk' target='_blank'>www.storme.co.uk</a>
visit me at http://www.janspeed.com
storme is offline   Reply With Quote
Old 08-02-2005, 01:43 PM   #3 (permalink)
Photos: 0
etc etc
[snapback]366669[/snapback]
I never heard of a reverse flush. How is it done. Thank you for the info.
Old 08-04-2005, 05:48 AM   #4 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3 | 1983 Yamaha something
Photos: 0
Yeah i've never heard of reverse flush also.
Thermostat, Water Pump, Fan Clutch.
PIPES. Check your pipes!
Old 08-04-2005, 08:50 AM   #5 (permalink)
schilke's Avatar
Photos: 0
schilke is an unknown quantity at this point
You can buy at autozone a 'Flush Kit.' Basically its some fittings that let you tap into your heater core rubber hoses. The reverse part is when you flush the system thru the heater core OUTLET, thereby reversing the flow of water thru the system.
On such a new car, I don't think that is necessary.
When exactly, and under what conditions, is it overheating?
ON Highway = Water pump, thermostat
At Idle = fans not working, thermostat
Need a new sig...
A BMW is for the soul, a Chevy is for groceries...
BAN KRAFTFAHRER!!!!
schilke is offline   Reply With Quote
Old 08-04-2005, 08:52 AM   #6 (permalink)
schilke's Avatar
Photos: 0
Crap!
Forgot about the radiator cap or rather the expansion tank cap. BMW expansion tanks are under pressure and if the cap cannot hold the pressure an overheat may result -- highway or idle.
Need a new sig...
BAN KRAFTFAHRER!!!!
Old 08-06-2005, 04:28 AM   #7 (permalink)
storme's Avatar
Photos: 0
A REVERSE FLUSH...............
your water in the radiator goes round in 1 direction...always....
so a reverse flush ,,is to flush the radiator and block by flushing,using a hose pipe. in the opporsite direction..
imagine the years of crud, all getting uded to going in the same direction...a flow pattern will appear,,,and all the crud will stick to it....
so if u reverse the flow,,it will take out most of the crud.....remember to remove the thermostat when flushing...
vB code is On
over heating. Cloxe 5-Series (E12,E28, E34, E39, E60) 3 10-02-2005 01:51 AM
Heating WarNox 3-Series (E36) 6 05-10-2005 11:51 PM
Car Heating Up Again- Help alext 3-Series (E36) 7 11-01-2004 08:18 PM
PLEASE HELP OVER HEATING PROBLEM bmwboyuk 3-Series (E36) 6 01-27-2004 03:28 AM
e23 heating system problem cyrex 6,7,8,X,Z - Series and Mini Cooper 0 01-02-2004 06:25 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
