oil light sensor/sender - BMW Forum - BimmerWerkz.com
Old 02-26-2007, 03:35 PM   #1 (permalink)
dplatow1 is on a distinguished road
I had my oil changed on my 2001 330 CiC. Two weeks later, the oil light comes on (yellow) for a few seconds just after i start the car and then it goes off. The oil level is fine and the mechanic say it's just a bad sensor/sendor.
Anyone have this problem? what should this cost to fix? I've had nothing but problems with this car and i'm about at my last straw. Too bad, because i love the car.
dplatow1 is offline   Reply With Quote
Old 02-26-2007, 05:41 PM   #2 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
Moved to e46 section. Your vehicle is an e46. Hopefully you'll get better luck in here, find what you need, and stick to BMW.
Old 03-01-2007, 11:43 PM   #3 (permalink)
Moderator
Dirty_Tool's Avatar
This is a pretty common problem. Fairly cheap and easy fix. No coding necessary, just drain oil, replace sensor and put new oil in.
DT
Old 03-02-2007, 09:11 AM   #4 (permalink)
Hootie is on a distinguished road
Pretty sure this is what you would need to replace.
Don't forget a new O-ring too.
I don't have your service manual, but I'd imagine it's located somewhere near the bottom of the oil pan. Look around for the existing sensor, it's probably held on by a single hex or philips-head bolt, like most other sensors on these cars.
Hootie is offline   Reply With Quote
Old 03-08-2007, 09:35 AM   #5 (permalink)
Caden07 is on a distinguished road
I had the same problem 2 months ago. The technician indicated a small leak around the junction between the oil pan and the metal hose(for lack of better term) that holds the oil dip stick. The hose was replaced and problem solved. Good Luck.
Caden07 is offline   Reply With Quote
Old 05-25-2007, 06:08 PM   #6 (permalink)
GRIDLOCK is on a distinguished road
Oil Level Senders are a common replacement item.
Easy fix.
-Located on bottom of oil pan (3 nuts)
-Drain oil
-Remove Oil Level Sender
-Put new Oil Level Sender in
-Bolt up
-Make sure the Oil Drain Plug is back on!
-Fill w/ 7qts.
GRIDLOCK is offline   Reply With Quote
Old 06-13-2007, 08:50 PM   #7 (permalink)
romansura's Avatar
romansura is on a distinguished road
there is eaven a bulletin on it in bmw for the sensor issues at bottom of the oil pan.
romansura@hotmail.com
Wateroo,Ontario,Canada
romansura is offline   Reply With Quote
whats up with my oil service light? hunter325i 3-Series (E36) 8 02-23-2007 01:27 PM
oil light, brake light.... speedybmw 3-Series (E46, E90) 1 10-01-2006 04:03 PM
Oil Service Light on??? WTF??? mrfc3s 3-Series (E21, E30) 7 05-05-2006 10:31 PM
Oil Service light fredrex 1,6,7,8 - Series and Mini Cooper 2 01-14-2006 04:44 PM
