Oil light dont shut off for 2 minutes after engine is on - BMW Forum - BimmerWerkz.com
Old 03-03-2012, 06:12 PM   #1 (permalink)
MrVon is on a distinguished road
My oil light don't shut of when when i start my engine. Can this be a bad sign, i just had engine replaced and took car from shop.
MrVon is offline   Reply With Quote
Old 03-03-2012, 06:18 PM   #2 (permalink)
42, The meaning of life
brettski's Avatar
Car: 2000 740iL Individual
Check the amount of oil in the engine.
It could be a bad oil pump taking its time to develop proper pressure, or a faulty oil pressure sensor. Is the engine noisey when you start it up and progressively quietens down after running for a while?
Riding in style
Old 03-04-2012, 09:34 AM   #3 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
As Brett says...
Just to add, what viscosity oil is in there? To thin oil would give weak pressure !
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 03-04-2012, 01:02 PM   #4 (permalink)
Why this sensor is so expensive i've seen on rockauto for ~160. Is there way to test it like measure resistance in my old sensor or can i take it out and clean it?
Will oil run out when i take the sensor off?
Old 03-05-2012, 01:41 PM   #5 (permalink)
Car: 1989 BMW 535i
rivroshaun951 is on a distinguished road
Another problem that could be a possible issue. I hate to be the one to bring up worse case scenario. Your new engine. Is it new or rebuilt used? And if so a possibiltiy might be to much bearing clearence. Does your oil light flicker from time to time? I don't think your oil sensor might be an issue (But yes please check this to make sure it is working correctly). If the oil sensor is bad sometimes some manufactures will design into the system that the car will not start. A fail safe preventing someone starting and running the car with no oil pressure.
rivroshaun951 is offline   Reply With Quote
Old 03-06-2012, 02:54 PM   #6 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Yeah, good idea Shaun... But wouldn't the Big-ends knock like a postman at startup?
Eso es todo!
BMW Part Market
New Member ?
Old 03-07-2012, 02:38 PM   #7 (permalink)
Car: 1989 BMW 535i
Yep it sure will knock.....if there was no pressure. However he still has some pressure. I am betting on the fact that after the engine wars up. Pressure returns to normal.
Random shut down and won't start back up/ check engine ltgreen77 3-Series (E36) 1 12-29-2008 11:22 AM
overheating engine after 15 minutes standing or driving slobman 3-Series (E21, E30) 6 07-28-2008 12:15 AM
Windsheild wiper fluid light on, dont know why! please help jheabs 3-Series (E21, E30) 2 03-22-2006 06:01 AM
Light Came Up Dont Know What It Is???? Justin318is 3-Series (E36) 5 08-20-2005 02:14 PM
520i High Beam Light Won't Shut Off apersaud 5-Series (E12,E28, E34, E39, E60) 1 10-06-2004 05:59 PM
