Oil Changes - BMW Forum - BimmerWerkz.com
Old 01-23-2005, 10:27 PM   #1 (permalink)
warell is an unknown quantity at this point
Hey all. I have a 2000 328i. I don't do any crazy driving freeway 90% of the time. At NErate. I need to get my oil changed and I don't really want to go the dealership.. A buddy of mine with a 98 bmw goes to Jiffy Lube.. Is this cool? Also what type of oil and how often. I am kinda over due and am going to be making a 2000 mile trip in the next couple of weeks..
Thanks,
warell is offline   Reply With Quote
Old 01-23-2005, 10:49 PM   #2 (permalink)
doughboyea's Avatar
doughboyea is an unknown quantity at this point
Send a message via AIM to doughboyea Send a message via Yahoo to doughboyea
Well, I do plan on taking my car to the dealer when I'm due for one.... only because i'm lazy. You could just do it youself. Get, i think it's 7 quarts or however many it is in car and change it. Give the old oil to a recycling center or a garage and change the oil filter etc. You will save lots by doing it urself. Just an idea though.
Dough
<img src='http://img.photobucket.com/albums/v298/doughboyea/car3.jpg' border='0' alt='user posted image' />
<span style='color:green'><u>Proud</u> Member of the BMW Community</span>
<span style='color:black'>1999 BMW 328i Jet Black
--Total Dinan Points: 5 --
<a href='http://dinancars.com/SeriesPrint.asp?prod=335' target='_blank'>----</a>Dinan Stage 1 Suspension<a href='http://dinancars.com/SeriesPrint.asp?prod=335' target='_blank'>----</a></span>
<span style='color:black'><a href='http://www.ajusa.com/cgi-bin/knfilters/start?r=ajusa&ajr_skey=e2398f2ee8c6388757f9e7fb800 a4cb9' target='_blank'> --</a>K&amp;N Air Filter<a href='http://www.ajusa.com/cgi-bin/knfilters/start?r=ajusa&ajr_skey=e2398f2ee8c6388757f9e7fb800 a4cb9' target='_blank'> --</a></span>
doughboyea is offline   Reply With Quote
Old 01-23-2005, 11:13 PM   #3 (permalink)
Thanks. I do plan on doing it myself in the future now that I am outta warranty but what about Jiffy Lube? I called and they said they could but I just didn't know if it was safe..
Old 01-23-2005, 11:38 PM   #4 (permalink)
catalyst. is an unknown quantity at this point
Send a message via AIM to catalyst.
I personally wouldnt feel good letting someone else change my oil, its very easy to do and there is no reason to spend extra bux for someone else to do it. Ive heard horror stories about jiffy lube too.. like them using impact wrenches on the oil pan drain plug and shit like that.
Its one of those things that is very easy to do, but if you want it done 100% right without any worries you gotta do it yourself.
catalyst. is offline   Reply With Quote
Old 01-24-2005, 08:59 AM   #5 (permalink)
imho:
non delaer hi thruput shops (jiffy lube etc) ARE DEATH FOR YOUR CAR.
so: diy (careful not to overfill, even synthetics foam up), trusted mechanic, or dealer.
Old 01-24-2005, 12:48 PM   #6 (permalink)
storme's Avatar
storme is an unknown quantity at this point
it is really easy to do your self,,,and the advantage is,,,you know exactly what oil is going in
i would use a fully sythetic oil a oem filter and 5w 30 oil,,,,or 0w 30
just do a s i do
jack up the car from the right hand side
get under it and locate the panel that is about 6in by 4 in
undo the screw
here u find the bolt to undo,,,undo it watch the oil drain away,,give in 1/2 hr,,make sure you do it on a warm car
then put the bolt back,,and re-fill
here in england we have 4 ltr packs of oil
so i use a whole one of these,,then add any extra with a smaller containers worth
visit me at <a href='http://www.storme.co.uk' target='_blank'>www.storme.co.uk</a>
visit me at http://www.janspeed.com
storme is offline   Reply With Quote
Changing Oil Filter Housing Gasket and O-Ring Live_the_Curves 3-Series (E36) 8 04-25-2010 01:34 PM
spark plug drenched in oil Beemerguru 3-Series (E36) 2 10-06-2005 10:06 PM
