New UUC Evo3 Short Shifter for 335i DIY - BMW Forum - BimmerWerkz.com
Old 03-13-2008, 09:56 AM   #1 (permalink)
wrh3's Avatar
wrh3 is on a distinguished road
I recently installed the pre-production version of the UUC Evo3 in my wife's 335i and wanted to share my DIY guide and feedback. I spoke with Rob at UUC shortly after installing the Evo3 in my M Coupe and was thrilled to hear they had one in development for the 335.
The shifter is not physically any shorter in height than OE, but the shorter throws and the more precise feel make this a desirable mod. The shifter replaces all of the plastic pieces with metal and the pivot bushings with bearings, this contributes to the smooth and precise feel.
On to the DIY guide, also found here: BMW MZ4 (E85/E86) UUC Evo 3 Short Shifter Installation
The UUC shifter comes packaged with all the pieces needed to install their Evo 3 short shifter. Additional carrier lock pins (circled below) are included if the installer desires to remove the carrier during installation:
NOTE: The following is provided for information only and any use of this information by you is at your own risk.
The first thing I did was to remove the shift knob (pull up hard), the shift boot (four clips, removed by tugging upward gently at clip areas), the foam insert around the shifter, and the carpet around the shifter:
The rubber boot can be carefully removed as well:
Note in this picture of the bottom of the boot the area that goes around the shifter carrier opening, this can be felt/positioned through the top part of the boot during reinstallation:
All of the pieces removed so far:
The plastic piece under the car is removed with an 8mm socket driver for access to the bottom of the shifter. The heat shield can be carefully bent back to allow access after using a 10mm socket driver to remove the driver’s side nut:
The shifter is held to the shift rod with a C-Clip, it can be removed with the help of a screwdriver:
The shifter is also held to the carrier with a plastic collar, it needs to be rotated clockwise to release from the carrier slots it locks into. This plastic collar can be turned by inserting needle nose pliers or a small standard screwdriver into the slots located around the perimeter of the collar. I was able to get the collar turned easily with two small screwdrivers- once the tabs highlighted are rotated clockwise about 90 degrees they are free of the slots that retain the bushing and the shifter can be lifted out of the carrier:
To install the UUC carrier pivot height adapter, the white ring bushing is placed in the adapter with the cup towards the top and Loctite is applied to screw holes on either side:
The pivot height adapter is installed next, it should sit flush with carrier base and the screw holes should line up with the slots in the carrier. Screws are installed loosely by hand and then tightened with supplied hex wrench alternating sides. After getting one screw on each side started it was much easier to start the other four using the one installed as a reference point. Be careful to get the screws just hand tight, no need to crank on the hex wrench (HINT: I found that using my grinder to cut down the hex wrench allowed for easier use):
Supplied grease is then applied to shift ball, order of components for installation into carrier from shiftball up should be nylon cup, spring, spring retainer, and snap ring. Also note the slight bend above the pivot ball to the left, the shifter should be installed with this bend towards the driver:
To install shifter in carrier, snap ring pliers are used to insert snap ring into adapter after shifter is placed in carrier:
Shifter is then connected to shift rod by placing bearing liners into bearing on either side, sliding shift rod pin through bearing, installing yellow plastic washer, and finally installing the C-Clip:
Heat shield is bent back to normal and bolted back up, plastic panel is reinstalled, shifter rubber boot (arrow on boot towards front of car), carpet, foam, shifter leather boot, and knob are reinstalled. When reinstalling the rubber boot, the lower seal for the smaller ring on the carrier around the shifter can be pressed on/around the carrier opening by feel through the rubber boot as the larger lip is press fit into the console body hole.
I am in no way affiliated with this vendor, just a satisfied customer, see UUC BMW Short Shifters for more information.
Bill
2007 BMW M Coupe, 2007 BMW 335i Coupe
BMW CCA Member # 389948
www.billswebspace.com/bmwindex
wrh3 is offline   Reply With Quote
Old 03-13-2008, 02:44 PM   #2 (permalink)
Teh Peetsa Gai
ldsbeaker's Avatar
Car: '86 325es, '87 535is
Thumbs up
wow, Awesome DIY. I wish I had taken pictures of my Z4 shifter install on my E28. It's basically the same... Funny how that works...
p.s. Welcome to Bimmerwerkz!! Great way to start!
My BMW Blog
Old 03-13-2008, 03:10 PM   #3 (permalink)
wrh3's Avatar
Thanks for the welcome
Bill
Old 03-13-2008, 03:47 PM   #4 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
welcome! NICE guide you make it seem so simple!
1992 318i Coupe parts car
I am Captain Obvious
Old 03-13-2008, 07:16 PM   #5 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
Short shifter for teh awesome. Wonderful write-up. This shall make it to our DIY section.
Turkey Fleet Bond Holder
Old 04-21-2008, 09:45 AM   #6 (permalink)
carbonem3 is on a distinguished road
Nice writeup! But I did the whole thing including the new bushings on the carrier. I can't get the clip back into the carrier all of the way. Any tips? There is no room to work in there and my arm looks like I was attacked by a cougar or some
carbonem3 is offline   Reply With Quote
Shifter have a lot off play,where to buy bushings or new aftermarket Short Shifter Slow325i 3-Series (E21, E30) 15 12-17-2005 03:42 AM
UUC Motorwerks Evo3 Short Shifter. Nunzio Product Reviews 12 08-22-2004 12:49 PM
UUC short shifter wolverine 5-Series (E12,E28, E34, E39, E60) 1 05-30-2004 10:27 AM
UUC Motorwerks Evo3 Short Shifter. pr0ximity 3-Series (E36) 0 12-31-1969 07:00 PM
