new replacement remote key - BMW Forum - BimmerWerkz.com
Old 12-05-2003, 08:25 AM   #1 (permalink)
bolle330i is an unknown quantity at this point
I am a proud new owner of a 2001 premium sport 330i. I found this board and this is my first post. The car only came with one remote key. The dealer is ordering me the valet and another remote key and is having them sent to my house. What do I have to do to make the remote work, or will it work automatically?
bolle330i is offline   Reply With Quote
Old 12-05-2003, 09:43 AM   #2 (permalink)
should work automatically if the dealer has any clue.
peter
Old 12-05-2003, 09:55 AM   #3 (permalink)
woobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond repute
Send a message via AIM to woobiee
im pretty sure you will need to get the dealer to program it; unless the dealer already first intercepted the key before sending it to your home.
woobiee - Anamorphic Cycle
woobiee is offline   Reply With Quote
Old 12-06-2003, 02:39 AM   #4 (permalink)
EXtech's Avatar
The dealer should program it for you when you go to pick up the new key. You obviously have to take the car with you, just ask them to program it. If they don't, then PM me and I'll explain how.
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 12-06-2003, 02:56 AM   #5 (permalink)
i had this experience with vw passat: i asked for an extra to be mailed. the competent dealer set the key just using my vin, then mailed it to me, and the remote worked fine. no reason this should be different in the bmw...
i think they do not like mailing keys because people can steal your car this way by just copying the vin, it is open for all to see in the windscreen corner. someone in this forum advised putting black tape over it (apparently not legal in new york).
peter
Old 12-06-2003, 05:33 PM   #6 (permalink)
AZ325Ci is on a distinguished road
welcome aboard bolle330i!! B)
once you get your key, take it along with your car to the dealer and have them program the key for you. before you leave the dealer, make sure that it works for everything. i had a similar incident where they lost the second key when i went to pick up the car. the second key was ordered and when i went to pick it up, they only programmed it to turn the ignition, but everything else wasn't programmed. so i had to make an additional trip back to get them to program it.
AZ325Ci is offline   Reply With Quote
Old 12-10-2003, 01:35 PM   #7 (permalink)
huntmdwn is an unknown quantity at this point
1. put the key in ignition and turn to position 1
leave for no more than 5 seconds
2.pull the key out
3. while holding down the release trunk button pressed firmly, press LOCK button rapidly 3 times
and it should initialize.
by the way, you have to redo all the keys at once but only do steps 1 and 2 with the first key( i think if i remem correctly)
huntmdwn is offline   Reply With Quote
Someone stole the key for my locking wheel nuts!!! KILOCHARLIE 3-Series (E36) 4 10-12-2005 04:30 AM
Remote Start help?! 007ben Audio and Electronics 9 09-30-2005 09:35 AM
Key remote interboss 3-Series (E46, E90) 9 09-15-2005 05:49 PM
Replacement Alarm Remote shandy Audio and Electronics 3 03-13-2005 07:05 AM
Two part numbers for same keyless remote? frank3 3-Series (E36) 3 10-31-2004 06:44 PM
