need tech advice - BMW Forum - BimmerWerkz.com
Old 05-21-2004, 08:36 AM   #1 (permalink)
Rob
Rob is an unknown quantity at this point
I have 01 325ci and the speedo, odometer and fuel consumption gage does not work. Does anyone know a way to fix this problem, perhaps a fuse, if so where?
Rob is offline   Reply With Quote
Old 05-21-2004, 11:12 AM   #2 (permalink)
Mach 5's Avatar
Mach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond repute
It could be a fuse, they are located in your glove box behind a drop down face plate. Be sure to replace the bad fuse with one of correct size. If it blows again you have a problem that may require alot of work to track down.
Ben
"It's not because I'm an aggressive driver, it's because I'm an idiot" actual quote from my wife.
Mach 5 is offline   Reply With Quote
Old 05-21-2004, 12:16 PM   #3 (permalink)
KillFox is an unknown quantity at this point
Send a message via AIM to KillFox Send a message via Yahoo to KillFox
Had the same exact problem in my old 94 mustang, it turned out to be a blown fuse from changing out the radio. A simple replacment fuse did the trick.
Check each fuse thoroughly in the glove box, and if you turn up nothing, I would suggest you go to the dealer.
<img src='http://3dwire.net/~matt/killfoxsig2.gif' border='0' alt='user posted image' />
KillFox is offline   Reply With Quote
Old 05-24-2004, 01:07 AM   #4 (permalink)
heifetz17's Avatar
heifetz17 is an unknown quantity at this point
Send a message via MSN to heifetz17
You don't need to go to the dealer just yet. If the fuses check out, check the connection where the instrument cluster plugs in. There may be a loose connection. I would check the speedometer cable to make sure it's in, and the sensor in the gas tank may be shot so it's not sending anything to the gas gauge. Just a few things to check before going to the dealer. If it's not under warranty, a reputable garage may be much cheaper than the dealer.
heifetz17 is offline   Reply With Quote
Need some advice on what to do with an E21 BMW 318i E21 Lover 3-Series (E21, E30) 11 09-22-2005 05:02 PM
newbie looking for advice please help träumer 3-Series (E36) 12 09-18-2005 11:49 PM
Need Advice On Buying A 94 540i bimerguyCW 5-Series (E12,E28, E34, E39, E60) 7 08-21-2005 08:57 PM
Bmw advice Midnhtsun 3-Series (E36) 10 05-22-2004 11:11 AM
