Need Some Info! - BMW Forum - BimmerWerkz.com
Old 04-09-2005, 06:59 PM   #1 (permalink)
zibby's Avatar
Car: yes
Hi Guys !
Does anybody knows what is about BMW SIB 24 02 00 and 24 02 02 please ! Zibby. (SIB stands for information service bulletin)
http://www.q8oils.it/
Old 04-10-2005, 01:30 PM   #2 (permalink)
I think there should be more digits than that, but I can tell you anything starting with 24 is related to automatic gearbox
Old 04-10-2005, 05:00 PM   #3 (permalink)
Moderator
Dirty_Tool's Avatar
24 02 02 regards hard shifting caused by a leak at the torque converter seal.
The fixes (depending on the severity) involve either installing a torque converter repair kit or a new transmission.
24 02 00 refers to hard shift or no shift with specific faults stored in the Trans module and the fix is most likely a new valve body.
DT
DT
Old 04-10-2005, 07:27 PM   #4 (permalink)
zibby's Avatar
Car: yes
DT
[snapback]329599[/snapback]
Thank you ! Zibby.
Sub Frame Failure, Im Worried, Need Info! BMW-ATI 3-Series (E36) 30 05-27-2005 01:29 PM
