Need Obd Ii Code Reader - BMW Forum - BimmerWerkz.com
Old 03-15-2005, 11:38 AM   #1 (permalink)
dh21187 is an unknown quantity at this point
Does anyone know if the 01 330xi's use an obdii port? If so what do you use to read it? I know you need a code reader I just need one that will work with my car. My check engine light is on and I want to know why without having to pay the dealer. ghead
dh21187 is offline   Reply With Quote
Old 03-16-2005, 06:26 PM   #2 (permalink)
Tom Busby is an unknown quantity at this point
Pep Boys sells the Accutron code reader (the top of the line reader with 4 lines of info') for $189. Autozone sells the same reader for $290! I bought one and it works fine, but the book it comes with is pretty useless at understanding some of the codes. But a friend used it on his Chevy and it told him exactly which of the 4 oxygen sensors was bad, so some of the codes have enough info' to interpret clearly.
On my 2001 325i trouble light code, I asked the dealer what the trouble code number really meant, got some free advice, and fixed my code problem, which was that the solenoid that checks for a gas tank vacuum was leaking, and which I repaired by taking the solenoid apart, regreasing the plastic seal, and reassembling. My trouble code was part of what people generically call the "loose gas cap" family of problems, but the gas cap had nothing to do with the actual problem.
Tom Busby is offline   Reply With Quote
Old 03-17-2005, 01:08 PM   #3 (permalink)
jehu3 is an unknown quantity at this point
Just take your car to Advanced Auto or Auto Zone, they will read it for you for free. They can look in their system and tell what part and how much.
jehu3 is offline   Reply With Quote
Old 03-20-2005, 10:54 AM   #4 (permalink)
clarkinc is an unknown quantity at this point
[snapback]313020[/snapback]
Does it give you fault codes for airbag lights or can you do your oil reset with it?
clarkinc is offline   Reply With Quote
Fault Code Reader?? eric 5-Series (E12,E28, E34, E39, E60) 2 04-14-2005 02:46 PM
Cheap Obd Ii Code Reader At Hf Gator Classifieds Sell & Buy 0 12-07-2004 04:02 PM
Sf Bay Area - Borrow Srs Code Reader frank3 3-Series (E36) 1 11-23-2004 07:51 AM
Fault Code Reader okczy21 3-Series (E36) 2 10-25-2004 08:44 PM
Fault Code Reader schilke North Central 2 07-22-2004 03:26 PM
