Need Help Installing A Subwoofer And Amp! - BMW Forum - BimmerWerkz.com
Old 11-28-2004, 01:54 AM   #1 (permalink)
m4rk is an unknown quantity at this point
I have a 2001 330ci and want to install an amp and subwoofer w/enclosure in my trunk. This is my first BMW install and I must say I am a bit lost. I am particularly curious where to hook the amp to so it will be ON only when the car is. Also, can I splice into my two rear speakers to get a signal to the amp/sub? I have the HK sound system, and the sub it comes with from the factory just sux. Thanks... ~m4rk
m4rk is offline   Reply With Quote
Old 11-28-2004, 04:10 PM   #2 (permalink)
v.o.r is an unknown quantity at this point
hmmmm if i where uid take it to futureshop or sumthing u might thinks it gay or wtvr but i think they charge 60 for the installation of everything i forgot how much it was exaclty but ye drop off ur car sit bak relax then get in ur car and listen to ur subs rattle ur car...thats what i would do to tell u the truth dont mess around with it if u dont know wat to do just take it to sum1 whoo knows how to.....take care
v.o.r is offline   Reply With Quote
Old 11-29-2004, 07:14 PM   #3 (permalink)
talisay is an unknown quantity at this point
DUDE, ITS NOT SO BAD INSTALLING THE SUB, I JUST INSTALLED SUB FOR MY 2001 330I YOU NEED TO GET SOME HIGH AND LOW CONVERTER FROM YOUR LOCAL CAR STEREO STORE. AND SPLICE TO THE REAR SPEAKER. JUST GET THE REMOTE WIRE FROM UR CD CHANGER WIRE. I THINK ITS GREY COLOR. TO BE SURE CHECK IT WITH 12 VOLT TESTER MAKE SURE THE IGNITION IS ON WHEN YOU CHECK THIS. U WANNA CONNECT TO THE WIRE THATS ONLY ON WHEN THE KEY IS IN THE ON POSITION, OTHERWISE YOU'LL DRAIN UR BATTERY,
talisay is offline   Reply With Quote
Old 11-29-2004, 08:04 PM   #4 (permalink)
Q_BMW's Avatar
Q_BMW is an unknown quantity at this point
Send a message via AIM to Q_BMW Send a message via MSN to Q_BMW
can bestbuy or circuitcity do it well too ?
Q
<span style='font-size:15pt;line-height:100%'><span style='color:red'>JUST SOLD:</span> <span style='color:blue'>01 BMW 330i with Sport &amp; M Package(5sp)</span></span>
<span style='font-size:14pt;line-height:100%'><span style='color:blue'>Past:</span> <span style='color:red'>1996 BMW 328i</span></span>
<span style='font-size:14pt;line-height:100%'><a href='http://www.ofoto.com/BrowsePhotos.jsp?&collid=10038932107&page=1&sort_o rder=0' target='_blank'>PICTURES!!</a></span>
Q_BMW is offline   Reply With Quote
Old 11-29-2004, 08:35 PM   #5 (permalink)
B3M2W5i's Avatar
B3M2W5i is an unknown quantity at this point
Send a message via AIM to B3M2W5i
Q
[snapback]239781[/snapback]
of course all you have to do is ask or buy something that they say they will install
Cashmere Beige Metallic
B3M2W5i is offline   Reply With Quote
Old 11-29-2004, 09:08 PM   #6 (permalink)
yep they can liek the previous post said i just gave u an example of futureshop
Old 01-15-2005, 11:17 PM   #7 (permalink)
dclaw is an unknown quantity at this point
Send a message via AIM to dclaw
I'm actually installing 2 jl 12w6's (old, I know.... they were in my 96 318i)
anyway.... thanks to talisay for the tip on the cd changer wire... I was wondering where I was going to get the +12v for the remote.... as my car is still in warranty and I'm not cutting wires at all.
I bought a set of molex 2 pin plugs .092" pin/plug size (check size)
anyway, I shaved/cut the molex plugs down to fit into the stock plug on the right speaker in the rear deck, so the speaker is still functional, but, I have wire I can splice into in order to get the signal.
I then ran this signal to a high-low converter, and then got it running to my amp via some rca's of course.
I am having one problem though.... which, for the life of me I can't figure out... HOW do you remove the battery tray?
I take off the plastic screws holding the tray to the body, but, it's stuck at the back by the fabric lining of the trunk... I can't figure out how to get it loose, anyone know what the hell I'm doing wrong?
good luck with that install.... doing it yourself is always much better.... and personally, I don't think most places bother to take the time not to cut wires, without charging you way too much extra......
dclaw is offline   Reply With Quote
