Originally posted by bad man working@Nov 11 2004, 07:00 PM The arms are grade to give the basic ildel setting this is factory set and if you mix them up your in bis trouble its trail and error and a smooth running programe on a BMW DIS tester if the cam wears renew it's far to precise to grind anfd therer's and load of special tool to work on the valvetroincs [snapback]228688[/snapback] |
i know about the tools, only for € 1200,- on timing tools incl valvetronic system tools
