My Engine Stuttles/ Vibrates In The Low Rpm - BMW Forum - BimmerWerkz.com
post #1 of 4 (permalink) Old 08-30-2005, 09:35 PM Thread Starter
junchoi is an unknown quantity at this point
I had this prob for a long time and Last month I finally changed the spark plug,
it seems fine but now its doing it again...
anyways It cost me $100 to Diagnose. so i need cheaper way to fix this prob...
I been ripped off to much
Please help!!! is there anyway i can fix this prob with $200?!
OR LESS Thanks....
junchoi is offline
post #2 of 4 (permalink) Old 08-30-2005, 10:25 PM
zibby's Avatar
Quoted: 1 Post(s)
OR LESS Thanks....
[snapback]373436[/snapback]
What is a milage on yours Bimmer? Did you scan for fault codes? Let start from here !
zibby is offline
post #3 of 4 (permalink) Old 08-30-2005, 11:58 PM Thread Starter
75000 miles... Thank you for the reply
I scaned for the false code it it shows that cylinder 4 was misfireing...
(this was long time ago -_-
but after changing the spark plug,
I checked the code and it only shows that the gas cap is loose...
even though car still stuttles....
junchoi is offline
post #4 of 4 (permalink) Old 08-31-2005, 01:29 AM
zibby's Avatar
Quoted: 1 Post(s)
[snapback]373468[/snapback]
OK! First use good fuel injector cleaner twice in the row (Chevron super concentrate) you can get it on Chevron gas station. Try to figure out , did it help with the symptoms you have. Another thing, my friend had this problem. The number two cylinder sparkplug boot was bad. We started trouble shooting by swapping the number two and three boots and the problem followed. Simply boot was faulty on cylinder #2-new boot problem gone! Check sparkplug boot on cylinder #4 , perhaps you need just new boot on cylinder four. Good luck.BTW did you chane the oxygen sensors in the past?
zibby is offline
Help...92 318I Gas Engine Sounds Like a Diesel ? DougJP 3-Series (E36) 13 04-11-2006 12:56 AM
Bad Engine Idle And Fault Not Found.. Paraklas 3-Series (E21, E30) 10 06-16-2005 10:25 PM
BMW P83 Engine triggrhaapi Bimmer Talk/Motorsports Talk 0 07-21-2003 03:03 PM
