Ok, so this one is a little different for me. My clutch is not slipping, it engages well, the issue I am having is when I push the clutch in to switch gears, the rpms stay up and slowly come down. It's like it is not disengaging completely. Anyone ever have this problem, and doe this mean my clutch is going or something else? Thanks!
that's normal on cars with drive-by-wire throttle ... manufacturers make the cars do that in order to make the gearchanges smooth and also something to do with reducing emissions or something ... google "rpm hang" or something.
Thanks for the info! You'll never guess what the problem was. After searching on the internet for 5 or so hours trying to see if there was something easy to check, I finally found something I thought I could check. I started looking and realized man that floor mat looks crumpled by that gas padel. hmmmmmmmmm...I moved it to it's normal position, took a spin, and everything is perfect again! YAY!!!!!!!!! HAPPY ENDINGS ARE GOOD UNTIL YOU REALIZE HOW BIG OF A MORON YOU ARE FOR NOT CHECKING THAT FIRST!
now
