Must change's for the Inspection 2 - BMW Forum - BimmerWerkz.com
Old 12-11-2006, 04:33 AM   #1 (permalink)
PhilH's Avatar
Car: BMW E46 318ci Coupe
PhilH is on a distinguished road
Wondering that the essential changes are
Microfilter
Oil/filter
Pluggs
Fuel Filter
PhilH is offline   Reply With Quote
Old 12-11-2006, 08:19 AM   #2 (permalink)
Hootie is on a distinguished road
In terms of years and mileage, what is your I2 at? I swap brake fluid every 2 years, tranny and diff every 4, plugs and fuel filter every 2 years, A/C filter every year.
Hootie is offline   Reply With Quote
Old 12-11-2006, 08:20 AM   #3 (permalink)
PhilH's Avatar
it's 49,000 and 5 years old.
Old 12-12-2006, 10:16 AM   #4 (permalink)
I would recommend (if it hasn't already been done on your car), all prices DIY:
-brake fluid - $25
-tranny fluid - $70
-diff. fluid - $40
-radiator fluid - $40
-spark plug - $35
-cabin air filter - $20
-intake air filter - $15
-fuel filter - $20
I would also take a look at the brake pads and rotors while the car was raised. If the pads are worn close to the point where they will activate the sensor, replace them ($40 per axle). If the rotors have a significant lip along the outer edge (from where the pad could not make contact and ground the inner surface down), consider replacing them ($80 per axle... and for the love of God, use anti-seize compound when putting the new ones on).
While you have most of the shields off under the hood when swapping plugs, I would check out the air intake duct all the way down to the ICV. Feel for holes, tears, worn or melted areas, etc.
You could also do a "Hot Soak" on your engine. Search the forums for this nifty $25 tune-up.
service questions thamindzzeye 3-Series (E36) 4 04-30-2003 02:40 PM
