Lumpy Pull Away In 330 - BMW Forum - BimmerWerkz.com
post #1 of 7 (permalink) Old 03-16-2005, 09:11 AM Thread Starter
Howie's Avatar
Howie is an unknown quantity at this point
Ever since owning my 330i Sport manual shift I have had trouble pulling away smoothly. I have to give the car a few more revs than when driving any other car. If anyone else trys to drive the car they stall the car as they don't give it enough revs. The problem is also when reversing, when I have to give it lots of reves or it judders as if it is going to stall. BMW have looked at the car about 4 times and have not come up with anything. It is driving me mad. BMW say it is due to the power in the engine. This is rubbish as I am used to driving Ferrari 360's with manual boxes. Any adeas anyone??
Howie is offline
post #2 of 7 (permalink) Old 03-16-2005, 09:40 AM
mikey_325i is an unknown quantity at this point
how many revs is "few more revs"? i think its fairly normal to hold about 2000 rpm to avoid the stuttering...you can go as low as 1000 with some practice on how the engine likes to be treated :P
--Mike
<img src='http://members.rogers.com/galaxycompu/bmw/bmwsp.jpg' border='0' alt='user posted image' />
<span style='font-size:12pt;line-height:100%'>2004 BMW 325i Sport/Premium</span>
mikey_325i is offline
post #3 of 7 (permalink) Old 03-16-2005, 09:54 AM Thread Starter
Howie's Avatar
It needs to be at least 2000rpm. I have drive many cars and this just does not feel right...
Howie is offline
post #4 of 7 (permalink) Old 03-16-2005, 10:14 AM
hmmm...well if ur not dropping the clutch too fast and applying enough gas to keep it above like 1500 rpm then id say there is likely a problem. get a bmw dealer to test drive ur car and go with them to see if it does it while they are driving it too.
post #5 of 7 (permalink) Old 03-16-2005, 11:53 AM
Sailor2 is an unknown quantity at this point
I have an 05 330CIC ZHP 6-speed and the clutching drives me nuts. I' ve driven manuals all my life so it's not me. According to popular opinion plus a talk with the local service manager, it's a combination of the clutch delay valve plus thorttle by wire, both of which screw up the timing for someone used to real-world linkage.
The only workaround is more and smoother revs (which makes you look and sound like an amateur) and slower deployment of the clutch. After a while you more or less adapt to it. There are blank CDVs available in the aftermarket but I don't plan to add one until the warranty is gone, some years from now.
BMW makes a fantastic car but this is an example of the engineers trying to outhink the end users -- it sucks.
Sailor2 is offline
post #6 of 7 (permalink) Old 03-16-2005, 01:09 PM
it takes some getting used to but you dont have to look like an amature when u try to get moving. you will eventually get the technique down - you just need to apply more gas then you normally would to get the needle moving up faster and you can start engaging the clutch even under 1000 rpm. play with it - its not that hard to get used to.
--Mike
post #7 of 7 (permalink) Old 03-17-2005, 04:09 AM Thread Starter
Howie's Avatar
--Mike
[snapback]312781[/snapback]
Well at least I know it is not just me with this problem. The dealership has told me it is a design fault. Apparently on a 328 they can put some M3 parts in, clutch or part of clutch or something, but on the 330 this is not possible.
Howie is offline
dyno results on real whp 325 vs 330 vs 328 dzenisn 3-Series (E46, E90) 23 12-01-2008 07:10 PM
New car 325xi or 330? tom kennedy 3-Series (E46, E90) 3 10-07-2005 09:06 PM
How Do I Pull The Ignition Key Cylinder On A 525i vifa84 5-Series (E12,E28, E34, E39, E60) 3 04-27-2005 01:40 PM
325 TDS LUMPY APROX1200/1300 RPM russ 3-Series (E36) 0 02-21-2004 12:28 PM
