Low oil! what's up? - BMW Forum - BimmerWerkz.com
Old 09-07-2003, 06:41 PM   #1 (permalink)
mastem is an unknown quantity at this point
Arrow
I need some help...my '02 330i, 10,000 miles, suddenly indicates low oil...I check it out and it is indeed just below the add line, needing one full quart oil....why would a fairly new car be burning oil?...no evidence of a leak....I'm no mechanic, but this seems odd.....should i be overly concerned....I'm going to call the dealer tomorrow
mastem is offline   Reply With Quote
Old 09-07-2003, 07:07 PM   #2 (permalink)
L337E46's Avatar
L337E46 will become famous soon enoughL337E46 will become famous soon enough
this is pretty common... Just add oil... No biggie... Do you have an automatic?
General, Troll Warfare Center: Task Force Troll/Founder BMW FORUMS 3.1415926535897932384626433832795 CLUB/Board Member Brotherhood of Huzzah/Board Member Troll Assassin Board/Board Member W00t! Club/Campaign Director Yanosh for President/Founder L337 Flash Club/Founding Member BMW Forums V1 Club/ BMW-Forums Badger Badger Badger arrgggghhhhhh club
L337E46 is offline   Reply With Quote
Old 09-07-2003, 07:29 PM   #3 (permalink)
5 sp
Old 09-08-2003, 08:53 PM   #4 (permalink)
shouldn't be REALLY doing this, when was the last oil change (kmls)?
i would not stress too much over this, i quart between changes is not terrible if it stays like this. some engines do this for tens of thousands of miles... have them check compression if you're paranoid...
i'd check carefully for a leak first.
peter
Old 09-09-2003, 11:03 AM   #5 (permalink)
hinchmant is an unknown quantity at this point
Had the same problem with an 03' 5 spd 330i. Low oil. Though I had to add almost 2 quarts at around 6k miles. Hasn't gotten any lower in the last 4k miles. No signs of an oil leak. Whatever it was must have happened early on.
hinchmant is offline   Reply With Quote
1998 E39 Low Revs Rough AndyN 5-Series (E12,E28, E34, E39, E60) 9 10-23-2005 02:39 PM
Headlight problem: City lights don't work (low and high beam do) KILOCHARLIE 3-Series (E36) 4 09-21-2005 01:33 AM
Seat memory weirdness -- what's going on?!? mrogers 5-Series (E12,E28, E34, E39, E60) 1 04-13-2004 02:16 PM
what's the best way to clean the headliner? AZ325Ci Wash & Detail 4 06-22-2003 05:27 PM
