loud noise from engine - BMW Forum - BimmerWerkz.com
Old 08-19-2009, 03:08 PM   #1 (permalink)
Car: 325i
05lcBMW is on a distinguished road
after a while of driving, the engine makes a loud high pitch whining noise. it only does it when i decelerate and when im at a stop. as soon as a accelerate the noise goes away. i put wd-40 on everything that rotates and the noise continues. does anyone have any suggestion?
05lcBMW is offline   Reply With Quote
Old 08-19-2009, 03:10 PM   #2 (permalink)
You may be on the hunt for a vacuum leak.
Old 08-19-2009, 03:21 PM   #3 (permalink)
Car: 325i
any suggestions as to where to look?
Old 08-19-2009, 03:24 PM   #4 (permalink)
It really depends on the individual car. Maybe a look at realoem.com can help
Old 08-19-2009, 03:36 PM   #5 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Cool
try WD-40 on the belts. still there?
A whine is always the effect of a pulley bearing gone bad. More so if the pitch of the whine changes as u accelerate or decelerate.
Contrast that to a "whistling" noise which is attributed to intake leaks.
What about when you are stationary(not moving) and u rev the engine... still there? You can go further by listening where the nois is greatest. that will help. :-)
Old 08-20-2009, 02:01 AM   #6 (permalink)
Car: 325i
yeah its a whistling noise. i did a a test where i warn um the car and take the engine oil cap off to see if the engine wants to turn off and it did want to turm off. so more than likely its a vacuum leak.
Old 08-20-2009, 02:08 AM   #7 (permalink)
Wink re:vacuum leaks
easy!
get ur self a can of brake cleaner. run engine at idle and start spraying sparingly at every place there you suspect a leak...
when u notice a change in idle as u are spraying... the point when the idle drops is also where the intake leak is ;-)
shope charge as much as $85.- do do dx like that.. I give my tips for FREE ;-)
Cheers
Old 08-20-2009, 03:03 AM   #8 (permalink)
Car: 325i
Thumbs up
thanks for your help.
loud noise. grex49 5-Series (E12,E28, E34, E39, E60) 3 04-04-2009 02:37 AM
How loud is loud when it's VANOS noise Wonderboy M-Series (M1, M3, M5, M6) 2 03-18-2006 01:07 AM
Loud Whistling Noise In Engine morristhecoolcat 3-Series (E36) 0 05-11-2005 02:54 PM
Loud Engine Noise And Head Gasket Problem dshrewd1 3-Series (E36) 0 11-12-2004 04:25 PM
loud engine noise and check engine light steviebhoy 3-Series (E36) 4 06-04-2004 06:59 AM
