I have had my 2001 330i for 2 weeks and have not used the washer spray as the pump needs replaced. I have lost about half the fluid in the tank. What are the most likely things to check? I see the sensor near the bottom. Are there any other penetrations or more likely a hose? TIA
Could, take some water, put a neon yellow highlighter in it and let it soak. Make sure the water is good and yellow, put the water in the tank. Go to a novelty store and get a black light, go lights out in your garage and trace the drips.
Easier and cheaper than getting a garage to look at it and it's still just water so it won't mess up your system.
Worst that can happen is you have to wash the car.
Good luck, let us know how it goes.
__________________ "I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones." - Albert Einstein
I had the same issue on my 2005. It turned out to be the rubber seal between the tank and the inlet to the pump. Took the tank out & separated the pump from the tank, smoothed the edges, applied just a hint of silicone and put it all back. So far, so good.
I'm not sure if your car has headlight washers, but, that's what it ended up being on my 2006 325xi. It would leak quite a bit while it sat idle in my garage and was impossible to find the leak location by sight.
everything is working well. Not sure why it appears to be fixe unless it has something to o with the way the pump was seate in the strainer? At this point I am not caring to much.
