loose nuts - BMW Forum - BimmerWerkz.com
Old 04-01-2004, 08:25 AM   #1 (permalink)
exjarhead328's Avatar
exjarhead328 is an unknown quantity at this point
Am I losing it???
On my way home from work last night I began to notice a periodic rumble and vibration that seemed to come from the left front side. I suspected to find something in the tire, but I had loose lug nuts!!!! I had just changed over to summer tires 3 days earlier and I know the lugs were tight. Even if I did fail to snug one up, all were in various states of escaping. Naturally I checked the others and several were loose. Could storing them all winter and then adding load be the cause. Maybe I'll take the bus.
SEMPER FI 2/3 Comm
Founder of the Four Pedal Club
2000 328
exjarhead328 is offline   Reply With Quote
Old 04-01-2004, 09:58 AM   #2 (permalink)
Graphic Designer's Avatar
Graphic Designer is an unknown quantity at this point
Send a message via AIM to Graphic Designer
did you torque them correctly or just tighten them snug. if you dont use a torque wrench, you will ruin your rotors and wheels in most cases especially if you have the stock BMW aluminum wheels.
garpihc dseigenr
(sp)?
Graphic Designer is offline   Reply With Quote
Old 04-01-2004, 09:59 AM   #3 (permalink)
you should torque them to 40lbs gvie or take.
garpihc dseigenr
(sp)?
Old 04-01-2004, 11:32 AM   #4 (permalink)
Mach 5's Avatar
Mach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond repute
Torque for the lug studs on an alloy wheel for a BMW in 100 Newton Meters. When Discount Tire put my current tires on they torque to 80 LBS/FT. Like Graphic said make sure that the lug studs are all Torqued evenly or you can warp a rotor or even the wheel in rare occasions.
Ben
"It's not because I'm an aggressive driver, it's because I'm an idiot" actual quote from my wife.
Mach 5 is offline   Reply With Quote
Old 04-01-2004, 12:33 PM   #5 (permalink)
thanks for the heads up guys, I'll get on this right away. Between 80-100 lbs? Pictures in the near future.
SEMPER FI 2/3 Comm
2000 328
Old 04-01-2004, 12:36 PM   #6 (permalink)
id torque them at 80... and just be sure to check on them in a couple of months.
garpihc dseigenr
(sp)?
Someone stole the key for my locking wheel nuts!!! KILOCHARLIE 3-Series (E36) 4 10-12-2005 04:30 AM
325i Lug Nuts ArenYarian 3-Series (E21, E30) 4 03-17-2005 09:32 AM
Loose Seat Belt ajames 3-Series (E36) 0 08-07-2004 04:55 PM
clutch cable loose??? javieruz 3-Series (E21, E30) 3 05-19-2004 10:26 AM
Loose hose... what/where? broketiltuesday 3-Series (E21, E30) 0 12-03-2003 10:44 PM
