LED interior lights/turn signals - Plug & Play? - BMW Forum - BimmerWerkz.com
Old 02-28-2006, 02:38 PM   #1 (permalink)
Ocean02 is on a distinguished road
I want to get rid of these crappy bulbs that I purchased that are just painted glass bulbs and replace them with LED bulbs. Here are the bulbs:
Interior (map lights) = 194 mini wedge
Interior (footwell) = 3175 dome bulb (36mm)
Front turn signals = 1156
I want the interior bulbs to be really blue. I found a few sites that sell LED lights, but my question is if these bulbs are truly plug & play. I think the interior ones are. However the 194 wedge bulbs I found have 4 LEDs in them. Will they fit/work in the overhead lamps?
Also, the 1156 LEDs. Are they plug and play?
Here's the 194 wedge bulb that I am contemplating:
LED interior lights/turn signals - Plug & Play?-194-4-led-blue.jpg
Ari Cohen
2002 BMW 325i
5spd manual
Ocean02 is offline   Reply With Quote
Old 02-28-2006, 04:54 PM   #2 (permalink)
miztuhdan is an unknown quantity at this point
Send a message via AIM to miztuhdan
Watch out for all those "blue" tone stuff. Those are painted. In order to give off a blue tone, you need a true Xenon. The color temp cannot get high enough with Halogens. So you might have the same experience with those bulbs as you did with your turns
Track Day-- Spartanburg, SC
United BMW Parts Department
miztuhdan is offline   Reply With Quote
Old 02-28-2006, 06:29 PM   #3 (permalink)
But all the LED advertisements say that they "give off no heat..." What's the difference between a filliment bulb and LED? They aren't the same, are they?
Anyone know if this bulb (and other LEDs) are plug and play and if they're safe, etc? Also, will they FIT???? Unlike the fat, stupid blue filliment bulb on my turn signal that didn't fit...
Thanks!
Ari Cohen
2002 BMW 325i
5spd manual
Old 02-28-2006, 10:35 PM   #4 (permalink)
jeremer is an unknown quantity at this point
The interior LEDs will work fine without any problem.
The turn signal will create a very nice flashing effect but you will need a equalizer for each LED. The turn signal will flash rapidly without the equalizer.
You can put the 194 LED into the side maker without the need of an equalizer. The bulb will stay lid (very dim) all the time and flash brighter when you turn on your blinker. It stays lid after you turn off your car completely for about 1-2 minutes.
One thing you will notice is all the LED (signals and side makers) will flash extremely fast for about 8-9 times every time you turn on your ignition. I do not experience this effect on my Honda Accord
Hope this help with your decision.
jeremer is offline   Reply With Quote
Old 03-01-2006, 07:57 AM   #5 (permalink)
storme's Avatar
storme is an unknown quantity at this point
i used LED lights on my car,,they worked fine without the flashing as described above...BUT my dash board reported that the side light were out...and put on the indicators lights as a backup..
they dont use as much voltage as normal lights..so it showed as a fault
they need to have a resistor fitted to work properly
visit me at <a href='http://www.storme.co.uk' target='_blank'>www.storme.co.uk</a>
visit me at http://www.janspeed.com
storme is offline   Reply With Quote
Old 03-01-2006, 09:38 AM   #6 (permalink)
AZ325Ci is on a distinguished road
check out our sponsor jlevisw.com. they should have interior bulbs you can use. also, bimmian.com sell Xenon bulbs for our interiors as well.
AZ325Ci is offline   Reply With Quote
Old 03-01-2006, 11:12 AM   #7 (permalink)
BMWERKEN's Avatar
BMWERKEN is on a distinguished road
Send a message via AIM to BMWERKEN
At the moment we do not carry interior lights.
We do have LEDs for your front, side and rear turn signals however.
Call Toll Free: 1.888.JLEVISW
PREDATOR ICE OEM ANGEL EYE UPGRADE | PREDATOR CHROMIUM ANGEL EYES | LED TURN SIGNALS
BMWERKEN is offline   Reply With Quote
