Key stuck in ignition - BMW Forum - BimmerWerkz.com
post #1 of 12 (permalink) Old 08-31-2004, 09:20 PM Thread Starter
harryd is an unknown quantity at this point
My key is stuck in the ignition, in the accessory position. I can turn it forward, and start the car, turn it back off, but only to the accessory position. I cannot turn it all the way back and remove it.
Does anyone have any idea what to do - the dealer says to bring it down
and they will look at it, they claim they havent seen this before.
2000 328 CI, forgot to mention its a 5 spd manual.
harryd is offline
post #2 of 12 (permalink) Old 08-31-2004, 09:24 PM
crisby_E30 is an unknown quantity at this point
Send a message via AIM to crisby_E30 Send a message via MSN to crisby_E30
i don't know if e46's are like this but i got my key stuck in my e30 somehow the steering wheel locked up and i had to turn the steering wheel as hard as i could while my friend to get the key out of ignition
<span style='color:blue'>Proud Member of the 100,000 Miles Club</span>
<span style='color
urple'>Proud Member of the 10+ Yr Old Club</span>
<span style='color:red'>Proud Member of the &quot;I'm 16 and Own a Bimmer&quot; Club
</span>
crisby_E30 is offline
post #3 of 12 (permalink) Old 09-01-2004, 11:52 AM
Mach 5's Avatar
Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute
This happened to me about a month ago on my 2000 328CI. I just worked the key back and forth a few times until it finely decided to give me the key back. It has not happened since. I speculate that the lock cylinder needs to be lubricated and it might not be a problem again.
Ben
&quot;It's not because I'm an aggressive driver, it's because I'm an idiot&quot; actual quote from my wife.
Mach 5 is offline
post #4 of 12 (permalink) Old 09-01-2004, 12:17 PM
CR320i's Avatar
CR320i is an unknown quantity at this point
Send a message via MSN to CR320i Send a message via Yahoo to CR320i
MY german e30, 320i 85 did that on sunday, I parked the car and turned the wheels to left, so it stayed that way all nite.
Next day it was locked and stucked.
A few times back and forth game the key back.
E30
1985/320i
german version
CR320i is offline
post #5 of 12 (permalink) Old 09-01-2004, 02:06 PM
320CDI is an unknown quantity at this point
This might be a stupid statement - but are you guys just turning the steering lock on? used
320CDI is offline
post #6 of 12 (permalink) Old 09-01-2004, 02:26 PM
Mach 5's Avatar
Not we are not turning the stearing lock on. When it happened on the e46 the wheel would still turn. The key would not fully return to the rest position.
Ben
Mach 5 is offline
post #7 of 12 (permalink) Old 09-01-2004, 02:41 PM
KillFox is an unknown quantity at this point
Send a message via AIM to KillFox Send a message via Yahoo to KillFox
I have had the problem once or twice, all I had to do was move the steering wheel till it locked and the key came out.
<img src='http://3dwire.net/~matt/killfoxsig2.gif' border='0' alt='user posted image' />
KillFox is offline
post #8 of 12 (permalink) Old 09-01-2004, 04:03 PM
2001BMW325xi is an unknown quantity at this point
Okay I think people are talking about two different thingmajigs here
If the key comes out of the lock by moving the steering wheel slightly here and there I think thats prolly due to you having engaged the steering lock when you moved the steering afte removing the key. Its an additional safety feature.
If the steering wheel moves freely and the key still does not wanna come out thats a whole different issue. Not that I know how to fix it....jst thought I might clear out the two different thoughts running here in this thread.
If I am wrong just me out ...... my 0.2$
2001BMW325xi is offline
post #9 of 12 (permalink) Old 09-01-2004, 04:50 PM
komodo's Avatar
komodo is an unknown quantity at this point
Just your twenty cents? Valuable opinion B)
komodo is offline
post #10 of 12 (permalink) Old 09-01-2004, 07:09 PM
LIX
LIX is an unknown quantity at this point
i got a 2000 328ci and this happened to me the other day, it also used to happen in my e30. Its when u turn the wheel slightly and try to take the key out simutaneously. The key gets stuck as the steering lock just kicks in , its like the lock is just about on, so the key wont come out. Dont worry it happens to loads of bmw drivers, a few twiddles as said b4 will make the key come out.
LIX is offline
post #11 of 12 (permalink) Old 09-01-2004, 08:22 PM Thread Starter
Thx for the comments....the problem was a stuck key, the steering was not locked as it moved freely, just couldnt move the key back from the accessory position, altho it would move forward, and start/stop the car.
After HUNDREDS of back and forth attempts, it finally got freed, and I could turn the key off and remove it. I was pressing the key in when it finally worked !
It seems ok now, I sprayed a slight amount of graphite lubricant into the key slot, I hope it helps prevent a recurrance.
harryd is offline
post #12 of 12 (permalink) Old 09-02-2004, 12:54 AM
KwlAznKid's Avatar
KwlAznKid is an unknown quantity at this point
Send a message via AIM to KwlAznKid Send a message via Yahoo to KwlAznKid
happened to my mercadez.. i waited for a few hours.. went bak and forced it to turn left and bam it came out haha ..
&lt;img src=&quot;
01 BMW 325 CI (mine)
93 MERCEDES BENZ S 400 (mom's)
03 INFINITI FX 45 (dad's)
KwlAznKid is offline
key won't turn all the way?! booger 3-Series (E36) 1 10-29-2005 07:46 AM
Someone stole the key for my locking wheel nuts!!! KILOCHARLIE 3-Series (E36) 4 10-12-2005 04:30 AM
stuck ignition Davetherave 3-Series (E36) 3 09-03-2004 08:00 PM
Ignition question snoopy M-Series (M1, M3, M5, M6) 2 07-06-2004 11:35 PM
Ignition locked - HELP! 318ti Ray 3-Series (E36) 5 12-14-2003 03:41 PM
