i JUST BOUGHT THE
Kenwood KDC-HD942U , And am wondering how to install. The Wiring guide states:
So i have the following questions:
1.
So i need an extra adapter from what is already coming out of the unit, since it says not supplied????
Where can i go about finding one?
I removed the radio and there are three connectors, 1 connector block, 1 aerial input, and what i thought was a ground, could possibly be the steering wheel input? The connector labelled 1 has a small 1 pin connector in it.
I have recently read you lose your steering controls when you add aftermarket radio, IS THIS TRUE?
I have subwoofers and an amp, and all the wires i needed to install it in a previous car.
2.
I plan on installing a subwoofer with AMP, will i need all of the following connections, or just the L + R Subwoofer output?
3.
I bought a dash kit from
Scocshe Industries And they said in the manual that i will need wiring harness
BW10B and it looks like this:
Does this look right from anyone who has installed an aftermarket radio??
The connector that is in the back of the head unit is a 16-pin connector. I have the wiring harness that Looks similiar to the one pictured above except this one fits into the unit.
4.
I am assuming this is one of the cables that run up with the Subwoofer Input leads right? it turns ON the amp or something? Also what does it mean when it says And does not have any resistance. ????
5.
Motor antenna Control, What do i do with this wire? I have no external Aerial, Is the one i have the film-type ?
Im new to this so please bear with me....
