Intermittent AC - BMW Forum - BimmerWerkz.com
Old 08-20-2012, 01:10 PM   #1 (permalink)
OGF
OGF is on a distinguished road
Intermittent AC
2000 E 46: AC works OK in AM before ambient temp. rises above 80 F. Output at vent registers 46 F. When ambient temp rises above 80 F. the output at the vent rises to 80 or even 100. I have had the 'freon' levels verified, replaced the blower motor assembly even the FSU (Final Stage Unit) but problem continues. I have tried making adjustments at the climate control panel in the cabin, however, that seems to have little or no effect. By slowing the fan motor and opening the windows I can hear the compressor engage when the AC switch is pushed on, (and go off when I switch it off). The Automatic switch for the AC seems to be working properly, however, when the ambient temperatures rises, or if the car is left in the sun, when the greenhouse effect causes the interior temperature to rise to 130 (while the actual air temp. is perhaps 95) the temp at the blower in the cabin will drop to between 100 F and 80 F at best.) I am told that the evaporator and all components 'appear' to be normal and unobstructed. Since others have probably had a similar problem and found an answer that goes beyond what I have already tried, I am open to suggestions.:http://www.bimmerwerkz.com/forum/ima...ilies/conf.gif
OGF is offline   Reply With Quote
Intermittent Converible Top barcodeguy Z3 / Z4 /ZM 0 07-09-2012 12:35 PM
Intermittent Horn fowens 3-Series (E36) 1 01-22-2010 10:05 PM
E39 Speedo intermittent mikkey9289 5-Series (E12,E28, E34, E39, E60) 2 08-19-2009 03:48 AM
535i With Intermittent Misfire V8-Schnitzer-UK 5-Series (E12,E28, E34, E39, E60) 11 05-16-2008 07:28 PM
Intermittent Prob 1985318i 3-Series (E21, E30) 2 10-26-2004 11:48 AM
