ignition coils - BMW Forum - BimmerWerkz.com
Old 12-10-2005, 06:03 PM   #1 (permalink)
davis_fan is on a distinguished road
ignition coils
sorry for starting alot of thread guys, but i have a question to ask about the ignition coil. It said on the code that i had a cylinder misfire and i changed all my spark plugs..sooo im guessing its the ignition coil...
so im just wondering how long i can run with this problem? because its pretty costly to replace around 4 of them.
oh and also i havent been feeling any shaking anymore ever since i fixed my intake boot and the cars running fine,but theres still this error code
also wheres the cheapest place to get ignition coils!?!?!
davis_fan is offline   Reply With Quote
Old 12-11-2005, 01:22 AM   #2 (permalink)
storme's Avatar
storme is an unknown quantity at this point
hi
if u have any misfire...it means that unburnt fuel could be entering the exhaust...if this is happening then it means that it could be damaging your catalytic converter...which IS very expensive
take it to an independant specialist..hook it up to the diagnostic equiptment and if a minute or two they should say which cylinder is misfiring..then change that coil
ps your said 4 coils?? does this mean you have a 318???? check and see if you have coils or just leads
visit me at <a href='http://www.storme.co.uk' target='_blank'>www.storme.co.uk</a>
visit me at http://www.janspeed.com
storme is offline   Reply With Quote
Old 12-11-2005, 03:30 PM   #3 (permalink)
bimmerboy328i's Avatar
bimmerboy328i is an unknown quantity at this point
Send a message via AIM to bimmerboy328i
What model do you have and what type of coils do you have?
- 97 M52 Beast - Vortech V-1 Supercharger Setup - Dinan Software - 28.8lb Injectors - 9psi - ZKW's - OEM Clears - DoubleSpoke II's - OEM M3 Spoiler - OEM M3 Front Bumper - 20% Tint - CCFL Angel Eyes - 6K Xtec HIDs in ZKWs - 6k H1 based D2S HID's in Foglights - Bilstein Sport Shocks - Eibach Sportline Springs - Cosmos Racing CAI - M50 Manifold Swap - UUC Motorwerks SystemU Exhaust - Fan Delete - 3.15 LSD -
bimmerboy328i is offline   Reply With Quote
Old 12-12-2005, 02:06 AM   #4 (permalink)
i have a 323i, and i sorry i said it wrong i meant i have 4/6 bad coils according to the the reader at autozone. He didnt tell me specifically which ones, and told me to change all of htem to be sure. My friend tells me i should take it to a shop and ask for their opinion, but i see nothing wrong when driving it around.
also i was wondering how much a shop would charge to replace them and also if there is a DIY for changing ur own ignition coils?
Old 12-12-2005, 08:57 AM   #5 (permalink)
A SIB is out right now for Bremi Coils. You might have them, so take them out and see if they are the Bremi ones. If they are, go to the dealer and get your new coils.
Old 12-12-2005, 12:02 PM   #6 (permalink)
AZ325Ci is on a distinguished road
i got the recall letter from BMW for the ignition coils. i plan on calling the dealer sometime later this week to set up an appointment to get them changed.
AZ325Ci is offline   Reply With Quote
Old 12-12-2005, 05:02 PM   #7 (permalink)
oh well the thing is my i dont have my warranty anymore so they'll still replace it or what?
Old 12-12-2005, 08:06 PM   #8 (permalink)
Yes they will, it's a recall.
Old 12-13-2005, 08:38 AM   #9 (permalink)
Hootie is on a distinguished road
In the event you don't have Bremi coils and you still need to replace them, check Bavarian Autosport for their replacement coils ($400 for set of 6, cheaper than OEM) or you can check Turner Motorsport for a set of used coils in excellent shape (set of 6 for $150).
Hootie is offline   Reply With Quote
Old 12-13-2005, 01:57 PM   #10 (permalink)
in any event that there's a recall, it is the dealer's obligation to replace the parts whether the car is still under warranty or not.
before you go buying coils, take the car to the dealer and ask them to do it. make sure that you mention about the recall.
Old 12-13-2005, 07:40 PM   #11 (permalink)
oh if i get a set of coils, is it easy to install them?
Old 12-13-2005, 09:05 PM   #12 (permalink)
Very simple.
Remove valve cover.
Flip up the connector and pull out plug.
Pull out ignition coil.
Very easy.
Old 12-13-2005, 11:58 PM   #13 (permalink)
if i change the coil, does that mean i have to get new connectors also?
oh i finally got a chance to write down the error codes in my car...and i have a ton =(..
P1250 - Early fuel evap heater circuit
P0300 - Random/ Misfire
P0304
P0130 - O2 sensor bank 1 sensor 1
P0306
P0305
P0173 - fuel trim bank #2
P0170 - fuel trim 4 bank #1
P1188 - Engine oil temp CKT Performance High Voltage
P1250 - Early Fuel Evap Heater Circuit
I was told by my mechanic that fixing the coils and 02 sensor will shut off everything...but i just wanted to know yall guy's opinion!
Old 12-14-2005, 02:23 AM   #14 (permalink)
Zapak4eva's Avatar
Zapak4eva is an unknown quantity at this point
Send a message via AIM to Zapak4eva Send a message via Yahoo to Zapak4eva
I also had to change the ignition coils, but luckily the car is still under warranty. The guy said that this is a problem in bimmers. Kind of a useless post but i just thought that i would say this.
<img src='http://i23.photobucket.com/albums/b360/Zapak4eva/BMWsig2.jpg' border='0' alt='user posted image' />
Zapak4eva is offline   Reply With Quote
Old 12-14-2005, 09:00 AM   #15 (permalink)
I had 2 cars that came in last night for the coil recall. The Z4 did not have any faults, but the E46 had a misfire in cylinder two. Replaced the coils, felt like the car was brand new. Get them replaced and see what happens.
What does your mechanic mean by everything is going to shut off?
BMW 1.8L OBD1 Ignition Coils Got 4 in Excellent Condition bacustoms420 Non-Automotive Related 0 10-12-2005 12:26 AM
BMW 1.8L OBD1 Ignition Coils Got 4 in Excellent Condition bacustoms420 Aftermarket Parts 0 10-12-2005 12:23 AM
BMW 1.8L OBD1 Ignition Coils Got 4 in Excellent Condition bacustoms420 OEM Parts 0 10-12-2005 12:10 AM
ignition coils killerjz Classifieds Sell & Buy 1 07-05-2004 11:57 PM
BMW Ignition Coils PoloBlue67 Classifieds Sell & Buy 2 12-30-2003 02:51 PM
