Idling,check engine and Same Freaking Code!!!!!!!! - BMW Forum - BimmerWerkz.com
Old 01-28-2010, 11:37 AM   #1 (permalink)
dcuse32's Avatar
dcuse32 is on a distinguished road
Angry Idling,check engine and Same Freaking Code!!!!!!!!
Hi, I have had the same problem for the past year. I have a 2000 BMW 328ci and Once in a while my check engine light will come on and I will notice that my car has erratic idling. I have a code reader and every time i do a diagnostic check it always says the same thing...Cam shaft sensor(intake side). the problem is I have replaced this sensor two times. I have even changed the cam shaft sensor in the exhaust side. Also after i reset the codes it will run fine until the next time i try to start the car. It will start but it takes longer to start then normal. It will also have hesitation while accelerating and at stop lights have erratic idling. I was told by Auto zone that it could be the camshaft sensor or the timing chain..Obviously its not the sensor but could it be the timing chain? or is it some thing else?.....Someone PLease Help!
dcuse32 is offline   Reply With Quote
Old 01-28-2010, 11:42 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Did you use genuine BMW sensors...if you did then they should be fine if however you didnt.......
Old 01-28-2010, 12:15 PM   #3 (permalink)
dcuse32's Avatar
I didnt. I bought them through pelican parts. Would that make a difference?
Old 01-29-2010, 02:58 AM   #4 (permalink)
marti5's Avatar
Yes, I purchased two non genuine camshaft sensors a couple of years ago and they both failed after around two months, I had camshaft error come up and thought cant be, so I went to BM, popped it in and hey presto....worked perfect, also avoid aftermarket MAF's they are way out.
Old 01-29-2010, 10:30 AM   #5 (permalink)
dcuse32's Avatar
Yeah but I just put a new one in last week and this is happening again. That why i was wondering if it could be something else.
Old 01-29-2010, 11:00 AM   #6 (permalink)
marti5's Avatar
Just checking....you did clear the code after fitting the new one?
Old 01-29-2010, 12:19 PM   #7 (permalink)
dcuse32's Avatar
Yeah, I clear the code every time it do it and without fail the same code comes up 41, which is camshaft sensor (intake side).
Check Engine Fault Code P1188 little jack 3-Series (E36) 6 10-30-2008 06:32 PM
check engine issues 1221 code seven 3-Series (E36) 10 03-26-2008 10:32 AM
Check Engine Code Wrong...what's The Deal? bimerguyCW 5-Series (E12,E28, E34, E39, E60) 1 07-03-2005 03:35 PM
Check Engine Light Code P1447 Pauls BMW 3-Series (E46, E90) 0 05-03-2005 12:33 PM
Check Engine Light: Code--e9 mathetas 3-Series (E36) 1 12-26-2004 07:38 PM
